QUOTE(SixerJ @ Sep 20 2017, 01:26 PM)
I know that we are not meant to comment on adverts, but I think it would help your sale if you added some more information and pictures of the parts
Oil tank condition? New but dusty, used & un-tested, used and tested (paperwork?), repaired, rusted out or what?
Spacer is a regular -6 or long hood spacer, GT spacers are totally different
Mag consoles as you point out are prone to mag rot. The lips can be repaired via machining and a new ring fitted. To seal properly I think that machining would need to be carried out on your unit (IMHO). Are the threads still intact after removing the steel adapters?
Photo showing the pressure valve screw, your angle doesn't quite show it but is it actually there? A buyer could not tell from the photos you have posted
Oil lines, the standard 911S 90 degree metal branches to the T Stat are no use in a GT set up, but the aluminium hose fitting is of use
Guessing the T stat is a regular 911 unit rather than one with the fixing bar on the back
You do have value in some of those parts, but price is a tad strong IMHO
Post more pictures and info on tank condition etc and I guess the market will decide
GLWTS
what he said and...
Is the GT spacer stock or a reproduction?
