Full Version: GB late side shifter bushings and bellow all for $20
Mikey914
Package for ALL the late side shifter bushings for $20
1 -911.424.139.00 ball cup
http://shop.914rubber.com/91142413900-Ball...91142413900.htm
1-914.424.224.02 trans mount bushing
http://shop.914rubber.com/Late-side-shifte...91442422402.htm
1-914.424.224.03 firewall bushing
http://shop.914rubber.com/91442422403-late...91442422403.htm
1- 91442423902 side shift bellows
http://shop.914rubber.com/914-late-side-sh...p3plqscsfapp006
2-911 424 223 03 shift knuckle bushings
http://shop.914rubber.com/searchquick-subm...eywords=Knuckle
I'll also offer the ability to add the cover and band for another $20 if you add to the GB $40 total)
Only catch need 10 takers for a GB.
I'll post up a thread.
Mark
Mikey914
Option to add these for $20
Also will run a few other GBs that can be combined to save a few bucks.
So,
Who's in?
nditiz1
I do need the cover so I'm in for 40
dlee6204
I'm in for everythig
JOEPROPER
I'm in for everything too. Thanks.
campbellcj
1 full kit with cover please
markhoward
Im in
mobymutt
Is there supposed to be a bellows at the firewall too, to protect that bushing? I'd be in if I can get that as well. I already have the large cover, but I need the band still.
87m491
In for all bits
QUOTE(Mikey914 @ Sep 22 2017, 10:15 PM) *
Mark
Jett
I’m in for the entire set ($40)
moe
I'm in for the $40
Mikey914
QUOTE(mobymutt @ Sep 23 2017, 08:48 AM) *
there is, haven't made that yet, but I will soon.
mobymutt
QUOTE(Mikey914 @ Sep 23 2017, 01:03 PM) *
Ok, I'll take the $20 buy, plus the band if you can do that. I might get you to hold on to everything for now, until I can get a bigger order together for shipping.
914_teener
I need the bushing kit. My cover is good.
Thanks Mark.
Mblizzard
I have all of these parts new from you Mark. But i encourage everyone to by a complete set along with some cone screws and and keep them in your car.
Can't find these when they fail and you need them. Very cheap insurance.
I am in. I have your cover and it is perfect!
seanpaulmc
I'll take a bushing kit.
wysri9
Mark
I am in for the full $40 kit please!
Calwaterbear
Hey Mikey,
when are you going to take pity on us guys with the old style crap.
Just pulled the whole shift mechanism, need to replace all the bushings , hoping you have a kit.
Mikey914
I do have the bands at the firewall and I need to do the ball, the housings and the firewall bushing. But yes I will do these.
Mark
Calwaterbear
QUOTE(Mikey914 @ Sep 24 2017, 07:28 AM) *
Mark
Can I assume you are replying to my request about early kits?
If so, any idea of a time frame?
mlindner
Mark, I'm in for every thing @40.00 plus any shipping you need. Best, Mark
Highland
I'd like to be part of the GB with cover and band.
Mikey914
QUOTE(Calwaterbear @ Sep 24 2017, 08:09 AM) *
Mark
Yes I am. The firewall bushings will be the 1st 8 weeks out.
The ball will follow in about another month
and lastly the housings. about another month after.
I do also have the bellows for the housing at the firewall.
At least that's the current plan. If I have a hot item I need to get in the cue it could delay these. Mostly a matter of ROI and where I'm at. I do plan for a very large cash infusion shortly, but we are discussing the merits of what should be directed where.
-Mark
flat4guy
I have not looked into this yet but I am sure it will tighten up the shifter - how hard is the bushing set to replace?
Mikey914
The knuckle one is the most difficult. It helps to have a press, but you can get creative with a vice. I could look at an exchange, but only have one handy right now.
Mark
Link to my install
http://www.914world.com/bbs2/index.php?sho...uckle++bushongs
Mikey914
I'll be sending PMs out shortly -
I have 3 GB items that are possible to combine
-This shift bushings GB
-GB for Mirror - Late
-GB for the positive terminal block that will be launching tonight
rhodyguy
In on the bushing package. No cover, mine and the SS clamp are fine. But not the bellows. I'll phone it in. Kudos to the team @ 914rubber!
Mikey914
Pms with codes sent to all at this point. I have included the GB information for the other threads, so if you signed up for more than one you may see a duplicate, I'll try to eliminate duplication.
Thanks,
mark
Grosbard
Great stuff! Assuming a '73 is "late", then i'm in for the full bushing set.
Mikey914
If you have this on your trans it's what you need. Hard to tell as many have been retrofitted.
NoEcm
Count me in for a set of bushings.
koozy
Count me in for it all
porbmw
Hi Mark
Can you put me down for the "complete kit" on this...
And when the time comes for the "early kit"...I will join the line!
Thanks
Paul
clapeza
I'm also in for the early stuff when it becomes available. I definitely need the hard plastic cover and the bellows.
Mikey914
QUOTE(clapeza @ Sep 27 2017, 12:02 PM) *
I will be able to provide shortly. They are in the works.
Matty900
QUOTE(flat4guy @ Sep 24 2017, 07:01 PM) *
I had everything out on mine and was switching from a tail shift to a side shift. Changing the bushings was pretty easy. I just used a vice to press the pin back in.
Matty900
87m491
Hi Mike,
I am having trouble catching up on these GB's. I am on 914world only occasionally and it seems luck when I catch these. I responded that I would be in for all the bits mentioned. I rec'd a PM later with GB #'s that I missed. I would be easier just to be invoiced once I committed to the buy. Conversely if you send a code, I should be able to go to the web site, punch it in and buy the bits. I put the code in your search bat and crickets.
Am I supposed to add all the items to the cart then go coupon code? While I really do appreciate the offers and have participated before, it seems tougher than needs to be to follow the dots.
Mike
Mark
NS914
Mark
I am in for the full $40 kit please! I can't thank you enough for supporting our addiction!
shall I just give you a call and give you my Visa number?
Regards,
Grant
mmichalik
If it's not too late, I would like to be in for everything as well.
Please let me know.
Thanks,
Mike
