brant
May 21 2005, 08:38 AM
I know this has been discussed at length...
I may of even asked it before.
but I tried the search feature for 10 minutes (dial up) with out luck
what is the torque value for the half shaft fasteners.
the inboard/outboard allen or 12point bolts
I have new washers
for some reason I think its 27 and I also think it is 12lbs...
what is the correct value?
thanks in advance
brant
rhodyguy
May 21 2005, 08:45 AM
31 ft lbs, as per haynes.
k
ArtechnikA
Spec Book says 4,3 MKg
4.3 x 3'/meter = 12.9 x 2,2 lbs/Kg = 28.38
there's a bit more than 3' in a meter -- i use 30-33 lbs-ft.
these should be 12,9 fasteners - that *is* a lot of torque for an 8mm fastener; "normal" is about 15 lbs/ft for your average M8 application.
brant
May 21 2005, 08:47 AM
thanks fellas....!!!!!
thanks a ton.
you guy are great!
now off to install half shafts.
b
