Full Version: dual carb gaskets and torque settings
nditiz1
I am reading conflicting information. Are you dual carb guys running the phenolic block gasket or the thinner fiber gasket on your intake manifold to head?
Also what are the torque settings for manifolds to head and carbs to manifolds?
Thanks, trying to clean up some intake leaks with proper sealing.
IronHillRestorations
Phenolic blocks help reduce heat transfer and fuel boiling in the float bowl.
I've never been good at remembering torque specs so I always double check specs, which in this case would be intake manifold to head, but IIRC 8-12 ft lbs
