QUOTE(targa72e @ Sep 27 2017, 10:51 AM)
I you wanted to go even lower or have another option, I have a 912 gearbox with a 6/29 ring and pinion which is about 8% lower than 7/31 it has the following gears.
5speed R:P 6:29 A GA O U Z
Mix and match with 914 gears and you could use flipped ZD for KA, and N from 914 box with U or V for 5th for gear with about the same overall ratios you were looking for.
I am in Colorado. Box is apart if you wanted to inspect.
thanks,
john
John,
wow.. .another amazing offer
thank you sir
and I think I've been able to refine my search and needs...
looks like I'm moving into difficult waters at this point.
I think I've got 1st -3rd covered...
now just needing to find a needle in a haystack for 4th
either an M -4th ratio, or an O 4th ratio, N ratio would work too, but can't say I've ever seen one. (both of which are easy to find for 3rd position, but not easy for 4th position)
I'm going to run an Hb 3rd gear and just need something lower for 4th to keep that jump reasonable
thanks again
where are you in Colorado?
I'm in Longmont, and hope we meet soon
by the way, I'm hosting a Colorado 914 gang bbq on the last weekend of October if you can make it.
brant
