QUOTE(Perry Kiehl @ Oct 1 2017, 05:59 AM)
The easiest and cheapest first level diagnostic would be a vacuum gauge. It can tell you a lot, or at least which direction to head in the next level of diagnostics.
Other option is to just watch your oil consumption, not including leakage. A quart 600 miles or less means you need a rebuild,now or very soon. A quart every 200 miles, means you needed a rebuild some time ago, and are living on borrowed time.
,PO didn't mention his oil level/consumption or the type of oil being used,are the spark plug oily or heavily covered in deposits.
I've seen a lot of cases where incorrect grade or type of oil will cause the issue he has,I don't run anything but a good 20/50 full zinc dino oil.
If everything is otherwise ok a compression test would be the next step.
