Full Version: Carbs pop sometimes
PanelBilly
I'll be driving along at a steady pace and I'll hear a pop. Any idea what's going on?
Running a 3.0 with PMOs
rhodyguy
Sound from where? Tail pipe or burping back thru a carb?
PanelBilly
Carbs. Might be a backfire. Not very loud.
rhodyguy
Take the filters off and see if you can get one of the venturi to sneeze. Does it happen at the same rpm consistently?
PanelBilly
I'll need to check. What do you mean "sneeze"?
GeorgeRud
Usually you start looking if the timing is too advanced or the engine is running lean. However, that will usually cause a fairly constant backfire through the carb, not just an occasional one.
IronHillRestorations
Pull the idle jets and soak them in carb cleaner.
