ClayPerrine
Oct 3 2017, 01:53 PM
I am selling the transmission from my six conversion. The 4.0 engine is going to use the boxster 6 speed, and this won't fit a 4 cylinder, so it is not needed.
1971 911 transmission converted to 914 side shifter. This uses the 71 911 225mm clutch assembly. It will fit any engine up to and including a 3.0 with no modifications (a 3.2 will have to have a notch cut in the bell housing for the DME sensor), and a factory 911 clutch. It has a billet intermediate plate, and a Guard torque biasing differential. The gearing is A,F filpped ZD, S, ZD. Gearing is great for a 2.4 S motor. I am including the clutch, pressure plate and flywheel. The trans does not need a clutch cable pulley, and it uses a 911 clutch cable. This means that there is no pressure on the clutch tube in the chassis. I can include the whole side shifter setup as well. Trans is well sorted, shifts great, and can be bolted in today.
The differential is going for around $1200.00. Parts for the trans rebuild are about $1000 these days. Clutch is 4 to 500 dollars for a kit.
Asking $9000.00. This does not include shipping.
It is still in the car, so I will have to pull it first.
Also, for full disclosure, the throw-out bearing is unique to a 70/71 911 and is getting a bit pricey. But I put a new one in about 3 years ago, and it has been down for 2 years with the engine problem.
Clay Perrine
sixnotfour
Oct 4 2017, 01:35 PM
Is 9000 correct ?? not judging , just checking , I have a pile of em
mb911
Oct 4 2017, 03:16 PM
QUOTE(sixnotfour @ Oct 4 2017, 11:35 AM)
I suspect your thinking just a standard sideshift trans.. Thats what I thought when I first read it..
ClayPerrine
Oct 4 2017, 03:19 PM
QUOTE(mb911 @ Oct 4 2017, 04:16 PM)
Yes, the price is correct. It is not a standard 914 side shifter. It is a 71 911 trans modified with 914 side shifter parts. It uses the 225mm clutch that was used all the way through the 3.2 engine. It also has a Guard Torque biasing diff, a billet intermediate plate, and it got new bearings, syncros, and sliders when it was built.
Definitely NOT a stock 914 trans.
sixnotfour
Oct 4 2017, 03:20 PM
QUOTE(mb911 @ Oct 4 2017, 01:16 PM)
70/71 911 ,,I now what he has ,,,and what I have
Larmo63
Oct 4 2017, 06:24 PM
I have a 2.4S engine in Underdog. This is exactly what I'd like to end up with in the car, but it's way out of the budget.
PlaysWithCars
Oct 4 2017, 08:55 PM
~$2,700 in parts (OP's numbers), plus some labor to rebuild. Are the 70/71 911 cores going for >$5,000 now? I knew early parts were going up in value but didn't realize they were that high now.
Too bad because this would be a nice trans to put behind the 2.4 that Jeff built for my car. I just picked up a Guard to build one, but this is plug and play.
ClayPerrine
Oct 5 2017, 06:52 AM
QUOTE(plays with cars @ Oct 4 2017, 09:55 PM)
You realize this is not just the transmission. It also comes with the throttle linkage, all of the clutch parts, and the complete shift linkage..
If you think I am too high.... then make me a offer.
PlaysWithCars
Oct 5 2017, 10:33 PM
Hey Clay, no disrespect meant. I'm constantly in awe of the rate at which early air cooled parts have been increasing and was surmising that the unique 70/71 transmission was what was driving the price for this kit.
No, I didn't see that ALL of the other parts were included in the package. This is a complete kit that will get someone well on their way for a -6 installation. GLWTS
ClayPerrine
Oct 6 2017, 08:38 AM
QUOTE(plays with cars @ Oct 5 2017, 11:33 PM)
None taken. I just wanted to clairfy what all was included. It is basically plug and play for a six engine.
