Mikey914
Oct 9 2017, 07:32 PM
As mentioned we've been working on these for some time. Just getting to finishing these up.
They change the airflow to help cool the engine better.
$28 A set who's in?
rnellums
Oct 9 2017, 07:36 PM
I'll take 2 sets!
JoeD
Oct 9 2017, 08:40 PM
Need a set Mark; I’m in!
dr.tim
Oct 9 2017, 08:46 PM
Yes.
bbrock
Oct 9 2017, 08:52 PM
Dammit! I'm in for a set, but I only need a half set.
gcrotvik
Oct 9 2017, 08:56 PM
1 set for me please.
deemsriddle
Oct 9 2017, 08:59 PM
I will also take a set. Deems Riddle
Mr. M
Oct 9 2017, 09:00 PM
I'm in for a set
7TPorsh
Oct 9 2017, 10:39 PM
I'm in...been waiting for these...
Mikey914
Oct 9 2017, 10:41 PM
Also, looks like I may even be able to make for LESS!! I'll keep all posted
JamesM
Oct 9 2017, 11:22 PM
Im in. I need at least 2 pair.
second wind
Oct 9 2017, 11:32 PM
Picture?
gg
djway
Oct 9 2017, 11:42 PM
Hand Up
Mikey914
Oct 9 2017, 11:46 PM
QUOTE(second wind @ Oct 9 2017, 10:32 PM)
Picture?
gg
I can add some pics in tomorrow
TravisNeff
Oct 10 2017, 02:05 AM
I am in for one set
mb911
Oct 10 2017, 05:24 AM
1 set for me.
GregAmy
Oct 10 2017, 05:46 AM
<---- two pair
clapeza
Oct 10 2017, 06:24 AM
I'm in for a set!
nditiz1
Oct 10 2017, 08:13 AM
Do these work better than the stock ones?
Mikey914
Oct 10 2017, 08:47 AM
QUOTE(nditiz1 @ Oct 10 2017, 07:13 AM)
The stock one work ok, we have been playing with adding some small "wingtip" vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it.
Mark Henry
Oct 10 2017, 08:50 AM
In for a set, one of mine is broke halfway through.
BeatNavy
Oct 10 2017, 09:01 AM
QUOTE(Mikey914 @ Oct 10 2017, 10:47 AM)
Geez, how can I resist a "wingtip vortex generator?" I'm in for a set.
Mark, I thought you just flew planes. I didn't think you knew anything about how they work
Mikey914
Oct 10 2017, 09:19 AM
One of the few aviation geeks that decided to build car parts instead of kit planes. However, I have made some parts for some friends experimental aircraft.
So not you too can fly low and fast across the ground
drem914
Oct 10 2017, 10:26 AM
I'm in for a set.
Garland
Oct 10 2017, 10:30 AM
I’ll take one set, please. Another great product
Grosbard
Oct 10 2017, 10:32 AM
I'm in for a set! Great work!
aharder
Oct 10 2017, 10:39 AM
I'm in for a set
brownaar
Oct 10 2017, 10:40 AM
I'm in. Have to work better than my current ones. New is always better anyway, right?
beech4rd
Oct 10 2017, 11:09 AM
Put me down for a set. Thanks.
second wind
Oct 10 2017, 01:10 PM
Pictures please and is there any quantifiable evidence of cooler temperatures? Just thinking out loud here....thank you.
gg
SKL1
Oct 10 2017, 01:38 PM
I'd be in for 2 sets.
raynekat
Oct 10 2017, 02:17 PM
Yeah what do these things do? 4 or 6 cylinder?
VoPo914
Oct 10 2017, 02:30 PM
I'm in for a set. Thanks!
GregAmy
Oct 10 2017, 04:11 PM
QUOTE(raynekat @ Oct 10 2017, 04:17 PM)
If you look under your car, attached to the bottom of the firewall (or, well, supposed to be) are two little air deflectors that hang down. They're supposed to be hanging down from the firewall.
The purpose of these are to - duh - deflect under-body air downward and create negative pressure behind them, under the cylinders. Due to this negative pressure the positive pressure at the top of the cylinders will cause air to flow faster/better downward through the cylinders and heads, improving cooling.
If you don't have these, you really should. It's actually surprising how effective they are.
Edit: found a photos online. It's that black deflector at the bottom of the photo:
hermich
Oct 10 2017, 05:18 PM
I'm in for one set...thanks!
pvollma
Oct 10 2017, 05:26 PM
QUOTE(Mikey914 @ Oct 9 2017, 09:32 PM)
$28 A set who's in?
I'd like a set.
914Sixer
Oct 10 2017, 05:27 PM
GREAT BUY!!!! The other guys are selling theirs for $49.95.
Mikey914
Oct 10 2017, 05:32 PM
And mine will be better NOT a URO part
raynekat
Oct 10 2017, 05:48 PM
QUOTE(Mikey914 @ Oct 10 2017, 04:32 PM)
Well Jeez....you better put me down for a set as well then.
gus'914
Oct 11 2017, 01:53 AM
dlee6204
Oct 11 2017, 02:09 AM
In for a set
914Next
Oct 11 2017, 02:45 AM
Here's a pic of mine when I took them off to clean the undercoating off....before and after.
nditiz1
Oct 11 2017, 06:02 AM
I don't think mine are in bad shape, but I'm in to try better ones.
Mikey914
Oct 11 2017, 06:11 AM
QUOTE(raynekat @ Oct 10 2017, 01:17 PM)
They weren't on the 6 as it was before their time. So from a concurs standpoint no. They will "work" on all. The idea is that the air is flowing past the opening where the engine compartment is and has been directed parallel for at least the 5-6' prior. So these are mounted at he firewall to create a low pressure area on the engine side. The hot air is sucked down and airflow is disrupted. The "vortex generators"are technically a wing-let that allows for more low pressure to build (a more efficient "wing"), and works at a lower airspeed. Honestly, the improvement I have made may only make the part 2-3% more effective (as it does in aircraft). So mine will not be 20% cooler than stock but there is data so show it is an improvement (at least on the aircraft side). Also we can easily shave these off for the CW should you you be in that crowd (and yes I do lean that way, but not a card carrying member).
Hope this helps with the concept and thanks for posting the pics up!.
hndyhrr
Oct 11 2017, 06:19 AM
I would like a set,please
JOEPROPER
Oct 11 2017, 06:28 AM
I'm in for a set please.
bbrock
Oct 11 2017, 08:02 AM
QUOTE(Mikey914 @ Oct 11 2017, 06:11 AM)
The amazing thing about this forum is that the answers come before I even have to ask the question. Thanks Mark! Definitely in for a set.
NeunEinVier
Oct 11 2017, 11:20 AM
QUOTE(Mikey914 @ Oct 10 2017, 06:32 PM)
Lol, too funny. Don't believe Uro manufactures these anyhow. Interested, adding it to my lengthy "would be nice to have" list.
EDIT: I stand corrected, apparently they do.
http://www.914world.com/bbs2/index.php?showtopic=317435
whitetwinturbo
Oct 11 2017, 10:12 PM
Yup
I'll take a set
rick 918-S
Oct 11 2017, 10:49 PM
In for a set.
