11tenths
Oct 12 2017, 08:20 AM
I'll take a pair of "Wingtip vortex generators", size 11 D, in brown, please.
- HB
IronHillRestorations
Oct 12 2017, 09:16 AM
I'll take two sets
CMONNETT
Oct 12 2017, 03:44 PM
I'll take two sets.
Thanks,
Mueller
Oct 12 2017, 04:08 PM
QUOTE(Mikey914 @ Oct 10 2017, 07:47 AM)
QUOTE(nditiz1 @ Oct 10 2017, 07:13 AM)
Do these work better than the stock ones?
The stock one work ok, we have been playing with adding some small "wingtip"
vortex generators. On the edges, it's a part that could be cut off for the concourse crowd, but would help improve the movement of air. I generally like to spring options right before the parts are ready, but yes there will be an improvement for those that want it.
How many volts?
Put me down for a set of "improved" upon design if make one.
rmdinmd
Oct 12 2017, 08:29 PM
in for a set
johnhora
Oct 12 2017, 08:42 PM
Oh I'm in for one set of those "wingtip" vortex generators also...
jim_hoyland
Oct 12 2017, 08:45 PM
I’m in too
jim_hoyland
Oct 12 2017, 08:46 PM
I’m in too
pete000
Oct 12 2017, 09:51 PM
Whe can we see these wing dings?
bbrock
Oct 29 2017, 10:04 AM
Just checking where this group buy stands. Three are a few other GB items I'm getting ready to order and wondering if this can be bundled in to save on shipping.
Mikey914
Oct 29 2017, 10:35 AM
These will be in the next wave. I currently have 6 GBs open including the master cylinder, and I found my site can only take 5 codes at a time. I have a few other new items and will be grouping my GBs to save all money. The only catch is that when this group is closed, it's closed. I can't carry them over indefinitely, otherwise why do a GB?
914-300Hemi
Oct 29 2017, 10:54 AM
I’m in for a set.
Mikey914
Oct 29 2017, 10:58 AM
QUOTE(pete000 @ Oct 12 2017, 08:51 PM)
I just need to finish some machining, but also working on the master cylinder assembly and testing so it may be 10 days or so.
Mark
bbrock
Oct 29 2017, 11:59 AM
QUOTE(Mikey914 @ Oct 29 2017, 10:35 AM)
No problem. Just wanted to double check before placing my order for master cylinder and drop link bushings. Will get them ordered today.
JimN73
Nov 3 2017, 11:19 AM
Mark, are these still open for Group Buy? One set please.
JawjaPorsche
Nov 3 2017, 11:57 AM
I would like a pair if still open.
Noonan
Nov 3 2017, 12:03 PM
I'd like set too.
cary
Dec 7 2017, 11:11 PM
Mark stopped by for a test fit on the new air deflectors. They fit perfectly and look great.
mxkinn01
Dec 8 2017, 12:29 AM
I too have one deflector that is broken and half gone. I'm in for a set as well.
914Rubber is the best.
bdstone914
Dec 8 2017, 07:42 AM
If a car was an early 70-72 than there are no holes in the body to install them. Some measurements or a template for installation would be very helpful.
Garland
Dec 8 2017, 07:44 AM
I’m still in for a set.
cary
Dec 8 2017, 07:52 AM
I can do that. I just drilled them in Doug's car.
Mikey914
Dec 8 2017, 10:51 AM
QUOTE(bdstone914 @ Dec 8 2017, 05:42 AM)
For a template you really only need to know where the 1st hole is for the side. The rest you can use the part to mark the holes.
I'm very happy with the fit on these the tool is a little rough so we need to do some more polishing.
Will probably take about a week as it's tool steel, and we can start some production
Rough test fit pics
GregAmy
Dec 8 2017, 11:28 AM
I need a box on the shelf out there. Just keep putting parts in the box until it fills up, tape over the top and ship.
If these get done about the same time as the suspension bushings are ready to ship, may as well add two pair to the bill.
bbrock
Dec 8 2017, 11:39 AM
And we FINALLY get to see what a vortex generator looks like.
walterolin
Dec 8 2017, 11:55 AM
One set.
Thanks - again.
74K914
Dec 8 2017, 04:56 PM
One set.
Thanks
cary
Dec 8 2017, 10:58 PM
Here's your starting point. Based on the 3 cars I looked at here at MiddleMotors the first bolt is 15mm from the jack point plate. But beware ................
Most cars have seen some sort of rust repairs so use the 15mm as a starting point. But make sure you can drill the holes and get your 8mm socket or nut driver on the other two 5mm bolts.
Click to view attachmentHere's the pilots modification the bottom edge.
Click to view attachmentI think Phil Knight has something like that on his G650.
I put them back on Doug's car for photos but forgot a couple shots.
Tomorrow
Mikey914
Dec 8 2017, 11:37 PM
Good news is I will be able to better the offer a bit too. More to come
914six
Dec 9 2017, 10:30 AM
Hi Mark,
would like a set also..
Thanks,
Harry
cary
Dec 10 2017, 10:26 AM
slotty008
Dec 10 2017, 01:13 PM
I'm in for a set.
Larry.Hubby
Dec 12 2017, 07:20 PM
If the buy is still open, I'll take a set too.
jcambo7
Dec 12 2017, 09:35 PM
I'm in for a set!
theer
Dec 13 2017, 09:31 AM
QUOTE(bdstone914 @ Dec 8 2017, 08:42 AM)
The Haynes manual has specific instructions (& measurements) on how/where to install these on early cars. I'll try to post pics later.
Tom
Mikey914
Dec 13 2017, 01:03 PM
Awesomeness thanks,
Mark
74 sunflower 914
Dec 13 2017, 02:42 PM
I would like a set as well.
theer
Dec 13 2017, 06:42 PM
QUOTE(theer @ Dec 13 2017, 10:31 AM)
Tom
Ok - here are the pics (from page 194 and 197 of the Haynes manual). Not much there, but hope it helps. I recall having to dig some seam sealer off the weld seam to drill the holes, but it's pretty easy job:
Click to view attachment Click to view attachment
Mikey914
Dec 20 2017, 01:22 AM
Just running these tomorrow will be sending PMs out tomorrow evening.
Thanks all
DRPHIL914
Dec 20 2017, 07:44 AM
can I get in on a set of these too Mark?
Mikey914
Dec 20 2017, 11:55 AM
Yep just starting to open this one up and we'll be shipping product here within the next week. Also got a couple other little goodies I'm going to put a group Buy on. The sign up here.
Mikey914
Dec 20 2017, 09:02 PM
Well looks like I will have to go into work early this week. I will be able to finish these up late next week, but will open these up with the rubber roof holders which we have changed the tooling on and improved them. A few of you may have got a set of these recently.
Mikey914
Dec 21 2017, 01:34 AM
PMs sent to all.
Thanks
Mark
tsvo
Dec 21 2017, 02:55 PM
Mark, I would like a set of air deflectors as well.
Thanks,
Terry
jesse7flying
Dec 21 2017, 03:20 PM
Count me in for a set. Thx. Maybe combine with the A arm tools?
Jesse
Mikey914
Dec 21 2017, 03:27 PM
QUOTE(jesse7flying @ Dec 21 2017, 01:20 PM)
Jesse
Unfortunately I think they all got shipped out. PM my your last name I'll check, if not no prob.
trojanhorsepower
Dec 21 2017, 09:03 PM
Aw man too late again!
Mikey914
Dec 22 2017, 12:05 AM
No not too late I'll send a PM, The other items close tomorrow night, so if you need a Back pad in plastic or the A-Arm bushings (w or w/o tool), and the trailing arm in stainless with bushings. You'll need the codes, let me know.
Codes sent to all so far..
Mikey914
Jan 2 2018, 02:44 AM
The other items that were on GB have closed out but leaving theses and the roof holders and cups up til the 15th.
