WTB-Parts
1. I need two good used belt mouldings that have the outer fuzzy strip to keep the window from rattling.
2. Clips for horizontal sail panel trim. I only have 3 of the arrow shaped clips, so whatever the balance is to mount the two trim pieces.
3. Clips and bolts/nuts, for the two sail panel pieces that has the curve in it.
4. Need the clips for the horizontal moulding that is just below the back/rear of the roof that is a trim piece on the rollbar. I have only one clip, so would need however many to mount it.
5. On one headlight, I need that offset/dogleg piece, and the bolt to mount it.
Also, just around the corner is a triangular shaped tab that has 3 allen head bolts that mount it.
