QUOTE(98101 @ Nov 26 2017, 04:17 PM)
I’ve got a carbureted big 4 with a 009 now. I’d like to make it more streetable and I love the idea of being able to fine tune everything over Bluetooth. I’m not sure the carbs are dialed in right but I’ve been told this won’t really be possible without decent ignition timing.
(More background on my situation here:
http://www.914world.com/bbs2/index.php?showtopic=320218)
I’m something of a newbie but as I currently understand it, the Bosch 009 isn’t a good choice for street use and maybe not even that great for a track car. I love the idea of being able to configure the 123, and the 12V switch to choose between two modes. I can see using one mode for cold start, try to get out of the parking lot without backfiring on a cold morning, and another mode for break like the wind! Also I think I might have fun and learn a lot about ignition timing with this distributor.
Four questions I’m still confused about after reading the thread thus far:
1) Will I need to relocate my oil pressure sender to make room for this, as has sometimes been reported with the Mallory?
2) Will I need to bend any engine cooling tin to get this in?
3) As I understand it, the Bluetooth version arrives with an empty brain. Would anyone else with a similar engine as mine (2270, Dellorto 45s, Web hot street cam, cool Pacific NW climate a little above sea level) be willing to share your configuration tables with me?
4) Did trying to use this distributor cause nditz1’s engine damage? Would I damage expensive parts by misconfiguring the distributor?
—Michael in Seattle
Michael I can answer 1, 2, and 4.
1. You will not need to relocate your oil press sender as this is the same size as the stock at least it seemed way smaller than the mallory i took out. I didn't micro it though.
2. See above, actually the mallory I took out did not need any bent tin, but was a very tight fit, much more room with this dist.
4. This dist did not cause my problem. While it was coincidence I think it was the 914 gods letting me know i need to do a partial rebuild with out leaving me stranded. I get my engine yoke tomorrow and will pull the heads. The outside inspection shows the previous builder swapped left and right head. This means the valve dropped on cyl 2 which was actually cyl 3 on the opposite side. Must have had a rough life.
