I picked up a parts car locally. It turns out it's really rough (hidden by a LOT of filler) and almost makes my car look like a good candidate for restoration . The only thing going for it is that it doesn't appear to have been in an accident. I'm trying to save the rear quarters. I cut my quarters off as shown below.
I have yet to strip the paint off of what's left of mine and clean out the goop underneath, but my bet is that what's still on my car is better than the same section on the parts car (especially around the door handle area). So, assuming mine are better (I'll know once I strip the paint off my car's quarters next Spring), my plan is to cut the quarters on the parts car and splice them into what's left of mine. The problem is, the donor pieces of the quarters will need significant repair and I'm not sure if they are usable and, if so, what is the best way to go about repairing them. Below are pics of each quarter and its respective trouble areas.
Right quarter full view:
Right quarter repair at door sill. The patch on the bottom is just covering rust that was pushed in, but I can't figure out what was going on with the long vertical weld line. The quarter has been pushed in all along and in front of the line, but it doesn't look like was accident damage.
The pinch weld at the taillight area looks good
Bad patch and a rust hole below the taillight area. The patch did not retain the shape well so there was a lot of filler over it.
Some rust, even after cleaning with an 80 grit conditioning disc.
Hammer marks?
Here's the left quarter:
For some reason the whole edge at the door sill is missing and was just filler. I wouldn't have to make too much of this because my cut line will cut off most of it.
Someone ground off the edge at the wheel well in spots. There's about a 4 inch section below this more obvious piece shown below.
There are dents and rust holes on the rear of the left quarter.
And kind of a gouge at the end. Someone brazed a circle, but it doesn't look like it was a patch??
A dent/kink with a hole.
The channel is quite pitted, which concerns me. Look at how much filler had been added to the edge of the fender; trying to get a nice seam on the trunk lid?
There is also rust pitting in the taillight area.
Also some rust at the lower front (seems to be a common area on these).
And some major scratches along the bottom.
So, what do you guys think? If I cut out the bad and MIG in replacments, knowing there will be filler needed, are they usable? The rust pitting in the channel really concerns me, but I'm guessing/hoping that the method of sandblast-rust convert-epoxy prime will work.
