QUOTE(Mueller @ Oct 26 2017, 01:01 PM)
Good info Mike,
I know you and I talked about this before,
What shift linkage do you use ?
Since my car has an adapter 901 to SBC would the Passat need a different adapter? Not sure what bolt pattern on the Passat/Boxer transaxle.
different Mike here
Boxster/Cayman shifter and cables can be used.
You would need a different or new adapter plate and flywheel for your SBC for the Passat or Boxster transmission. Have you considered going LS-based motor instead of the SBC? Might be easier to sell it as a package deal.
Thanks other Mike,
Ya I have thought of LS, Subie, and -6 but if it ant broke don’t fix it. Just thinking one day that poor old 901 is gonna blow. The Boxter trans looks like too much fab work to adapt. Anyone ever fit the whole Boxter engine and trans in a 914, I remember hearing issues of being too wide between rear of the engine compartment, hits the trailing arms ???
