We're building up a 1.9L and keeping the stock 1.7L D-jet system. We're utilizing a 1.8L cam. Looking for info from others who've done this upgrade with success.
What about injectors? ... are the 1.7L injectors adequate, or will they run too lean? If they won't provide enough fuel, which injectors have you guys used with good results? ... 1.8L, 2.0L ?
I understand the MPS will probably need to be re-calibrated. How did you go about doing this? ... sent it out somewhere or just fiddled with it until the A/F readings were good ?
Any other recommendations, tips, etc. you can provide ?
TIA ...
