QUOTE(burton73 @ Oct 24 2017, 09:57 AM)
Hi Brent,
How much more can it cost? It sounds good. What size would you use .025?
I may be cutting the rear fender of my V8 car to pump out a flair for a 8 inch wheel
Bob B
I'd use .023. It is available in .023, .030, and .035. It is $67 for an 11 lb. spool. $80 once shipping is added. I haven't seen 2 lb. spools unfortunately. Might be able to eliminate shipping by ordering through the local welding supply. They only have .030 in stock.
QUOTE(mb911 @ Oct 24 2017, 10:01 AM)
Works the same.. I actually used 2 spools of it.. Not anything exciting..
Well that is disappointing. I haven't figured out how to avoid shrinkage around my butt welds on sheet metal so I still get a few annoying little lines around the weld after grinding. I read on H.A.M.B. that you could use a hammer and dolly on this stuff to restretch the weld like you can with TIG. Not so?
