pgollender
Oct 24 2017, 12:46 PM
Is the stock bearing surface supposed to be flat or round when new or reground ?
Old:
Click to view attachmentRegrind flat ?
mgphoto
Oct 24 2017, 12:55 PM
QUOTE(pgollender @ Oct 24 2017, 11:46 AM)
Old:
Click to view attachmentput it on a flat metal surface, should rock slightly.
porschetub
Oct 24 2017, 02:41 PM
You can but you will have no hardening @ the end,the valve tip will chew these up in no time,so the answer is no.
Dave_Darling
Oct 24 2017, 10:35 PM
Like with lifters--flat is dead, and re-grinding only works if you can re-harden them after.
--DD
bdstone914
Oct 24 2017, 10:44 PM
New ones are about $14 each from Porsche. You may want to consider 911 swivel feet which are about $20 each. It looks like you have the early 1.7 rocker arms with the 8mm adjusters.
pgollender
Oct 25 2017, 07:24 AM
Got it !
Tossed the old ones. Ordered new stock. Didn't know about the hardening ends.
Mark Henry
Oct 25 2017, 07:39 AM
QUOTE(bdstone914 @ Oct 25 2017, 12:44 AM)
Why the heck would you pay Porsche prices for a VW part?
8mm is $15
set german, good for 1.7
http://www2.cip1.com/ProductDetails.asp?Pr...de=ACC-C10-523910mm is $34 set, for 1.8/2.0
http://www2.cip1.com/ProductDetails.asp?Pr...de=ACC-C20-5250
