Hey peeps,
Just got in from messing with Gunta - I followed some of your advice and checked the float levels (one was off a little, so I adjusted it back to spec), and checked the jets, which are all unclogged and clean. Fuel pressure is 2.5, and there is but the smallest occasional drop into the carb throat from the #3 orifice at idle, which almost disappeared after dropping the pressure at the regulator. The jetting is stock 40IDF, (115 main, 50 idle, etc) which I would guess is even a little on the lean side for my setup - 2056, Euro H cam, 050 dizz, and dual 40idfs. This thing runs so rich, that your eyes burn after just a few seconds behind it! Revving it makes it look like the smoke machine at an Ozzy concert for cripes sake. You can see the gases make a nice cloud that fills the garage when I pull it out, woohoo.....
Sigh
The ONLY thing I changed was the damn intake manifolds, I replaced a set of stubby shorties, with a set of tall ones. They are about 1.5 inches taller (maybe around there IIRC) and are ported immensely to match the intake ports on the heads. (I have some mild headwork as well, on the exhaust side). Could these intakes be the culprit? Do I need a set that haven't been ported? I'm hoping that's the problem
Any ideas?
Man this stinks
