Full Version: Pin size for Clutch cable attachment?
Calwaterbear
Making progress, need to hook up the clutch cable saddle to the pedal assembly, can't seem to find my little magnetic dish of parts. anyone know the size of that pin? and I assume it needs to be one with a hole for a cotter pin, right?
GeorgeRud
It’s actually a pin with a metal ‘hook’ that clips onto the Clovis to hold it in place.
Dave_Darling
http://www.pelicanparts.com/More_Info/2117...&SVSVSI=978
--DD
76-914
FYI, 6mm. McMaster Carr sells one that fits if you can't locate OEM.
Calwaterbear
Thanks guys, Dave, that explains alot, I do have that clip, in the meantime I used a 6 mm pin, so i guess I'll go in and change it to correct, and keep the pin handy for failure!
