All, need guidance on seals and rub strips for the targa top. Mine leak air and squeak when the top is installed (that I'm now noticing, with the cooler days here in New England).
Keep in mind that I can't simply look at the car and replace what's damaged. This car was a rescue, and much of the stuff that should be there is not (and the other car is a race car that had pretty much everything removed). For example, I had no idea that the doors had edge seals on the aft edge of the glass simply because nothing is there...
I'd appreciate in "idiot's guide" on what should be there to seal, stop air leaks, and noise, with links to the proper parts on 914Rubber a big plus. About to get into the GB for master cylinder so I'd like to do a MegaBuy.
Thanks!
