QUOTE(Rand @ Nov 4 2017, 12:41 PM)
You could get gasket material at a FLAPS and make your own. Satisfaction bonus. Press it against the surface to make an impression so you know where to cut.
I tried making my own but it doesn't seem to be sealing well. I am trying to chase down a vac leak that I think is causing my idle to hunt. I sprayed some carb cleaner at this location and the idle settled nicely. I checked the bolts and one was kind of loose. Tightened both bolts and retested and nothing changed. I am puzzled so I thought I can easily change this gasket.
