meares
May 25 2005, 01:49 PM
redshift
May 25 2005, 02:25 PM
Wait wait wait... injected?
Is it stumbling? If these are the symptoms, sput... taa taa...sputt...aaa... and injected, may be a simple TPS cleaning/readjustment.
That help at all?
M
goose2
May 25 2005, 02:40 PM
It could be lots of things, but when I had a similar sounding problem it turned out to be the trigger points. One each of the two contact sets triggers 2 injectors. If the rubbing blocks get worn down, 2 cyls. stop firing...seems to happen first at higher rpms for some reason.
meares
May 25 2005, 02:55 PM
i just turned the grey knob at the "box" (i guess control panel/box) all the way to right...clock-wise. it idles better but DAMN i smell A LOT A LOT of fuel..i'll turn it back down......it seems like now that it 'loads up' at 2 or 3 revs now instead of waiting for 4000. ..............Where are the trigger points?...THANK YOU !!!!!!!!!!!!!!!!!!!!!
meares
May 25 2005, 03:14 PM
are the points in the dist. cap?
mihai914
May 25 2005, 07:10 PM
The trigger points are in the distributor but all the way at the bottom where you have the 4 or 3 contact plug. You will have to remove the whole thing. Try and clean them because they're much more expensive than the ingnition points.
Mihai
Markeydoo
May 25 2005, 11:22 PM
My 2.0 was doing the same thing. I changed out every thing except the trigger points. Got feed up with it and took it to get serviced. they replaced the trigger points and now it runs great.
Mark
meares
May 30 2005, 02:01 PM
if i go to an XR 3000 and all the related side items that it needs will it eliminate the need for the fuel inj. points?
lapuwali
May 30 2005, 02:06 PM
No. However, trigger points generally only need replacing every 40-50K miles, and never need adjusting.
meares
May 30 2005, 02:07 PM
are the 1.7 and 2L interchangable?
mihai914
May 30 2005, 02:25 PM
QUOTE (meares @ May 30 2005, 03:07 PM) |
are the 1.7 and 2L interchangable? |
Yes they are.
Mihai
meares
May 31 2005, 06:27 AM
how many do i need to buy 2 or 4?
mihai914
May 31 2005, 06:31 AM
Just one, it's all in one unit,finally found a picture.
Mihai
meares
May 31 2005, 06:49 AM
pelican parts you think????
moneysmarts
May 31 2005, 06:56 AM
PP has got them.
Or you can try this link.
http://www.autohausaz.com/catalog/lookup_p...categoryid=6064Let us know if changing the trigger points solves the problem.
I've had a very similar issue and have not yet resolved it.
Maybe mine's the trigger points, too.
moneysmarts
May 31 2005, 07:43 AM
Rhodes71/914
May 31 2005, 12:58 PM
It amazes me how many FI problems are fixed with new trigger points. I recently had a stumbling problem at a certain rpm range which progressively turn into a no run issue. I went through a bunch of ignition and fuel troubleshooting before I finaly changed out the trigger points to a spare I had. Fixed the problem immediately.
I will now always carry a spare set.
meares
Jun 1 2005, 09:08 AM
if i can get the shop to pull it in and look at it i'll let y'all know what it is.......the shop works on A LOT of cup cars so it's hard to get any respect, BUT my $86/hour is the same as theirs!!!!!!!!!!!!!!!!!!!!
