redshift
May 25 2005, 04:48 PM
NEW CAR!
My starter either has a dead spot, or the whole thing is dead, I can't decide which, nor can I spend time worrying about it tonight. Had to push off from work, and tried starting it ten times on the way home while rolling... no go..
I am dragging her in for major service, everything is being fixed, and then she's on the block.
Anyone coming this way from CAMP914?
MCCLHASACARFORMEIJUSTKNOWIT
Toast
May 25 2005, 05:36 PM
If you can't start it, how do you know the motor is noisy?
Joe Bob
May 25 2005, 06:02 PM
Didya try banging the solenoid with a BFH?
redshift
May 25 2005, 06:04 PM
yaya mikee.. I tapped it with a sledgehammah..
Toaster... it's called FLINTSTONE START-DA-DABBA DOO!!!!
Uhh.... anything in the aisle... say odd numbered, and higher than 42?
M
redshift
May 26 2005, 12:23 AM
Ok, after doing nothing at all to it, it still won't start. Who advised letting it sit? Was that you Mike?
M
SGB
May 26 2005, 08:28 AM
With higher compression than stock, I had to back timing off about 2 degrees or so or else, SOMETIMES, it seemed the ignition kicked back against the starter when the engineALMOST fired and made a hellofanoise (KAWHAM!). I fried a solinoid, replaced starter, still had WHAM sound, then as a result of improved carb action which put idle at about 1200, I retarded diz a tiny tiny bit and now startup is EZ. As an experiment, it might be worth trying this anyway...
Joe Bob
May 26 2005, 08:40 AM
Sounds like it's time for the 1.5hp Bosch SR68X....
