QUOTE(second wind @ Nov 10 2017, 01:38 PM)
QUOTE(somd914 @ Nov 10 2017, 04:06 AM)
Do you smell gas when trying to start? If you pull a plug after attempting to start is it soaked with gas? As for weak spark, assume this is based on pulling a plug and cranking with the plug grounded against the engine case or other good ground?
If she is flooding, I'd take a look at your CHT sensor. A bad sensor or broken lead/harness wire on the CHT can cause flooding and no start, even to the point of showing no willingness to kick/pop.
Wow Somd914....you are describing it exactly as it is. I am judging the spark with a spark plug pushed against a part of the engine....very weak spark....lots of gas smell....while repairing the blown out spark plug I nudged and pulled on all the wires in the area. I will get back in there and double check all of the wires. How do you test the CHT? Thank you.
gg
It's been a while since I messed with D-Jet, went carbs several years ago.
I'm looking for the resistance specs and D-Jet harness pin out, but you'll need a multimeter to read the resistance of the sensor. Its resistance changes with temperature to change fuel enrichment. With high resistance or an open such as a broken lead wire, the mixture goes very rich and the engine won't run.
First step is to disconnect the CHT from the D-Jet harness and test the resistance at the CHT connector. If out of tolerance, then replace the sensor. If it's good, reconnect the CHT connector to the harness, then you will need to pull the harness cable at the engine control unit and test resistance from the control unit connector.
In my case, I had a broken wire in the harness a few inches from the CHT connector. It made intermittent contact, so it would run occasionally then die, or it would crank with no signs of firing off, just flooding.
Sorry, I'll see if I can track down resistance specs and control unit connector pin outs, or perhaps someone else will chime in...
