freezing14
May 26 2005, 08:20 AM
that was on my 2.0 parts car,, the engine will be running after the guide job,, but should i put that muffler back with the 2.0,, and what is it from,, it just says KADRON made in bresil???
Allan
May 26 2005, 09:44 AM
Got a pic???
May 26 2005, 10:20 AM
tat2dphreak
May 26 2005, 10:21 AM
didn't KADRON make carbs for beetles?
freezing14
May 26 2005, 11:06 AM
something went funny when i uploaded the picture,, here it is
Mueller
May 26 2005, 11:11 AM
if "need" a muffler, that'll work, but I think you'd be better off throwing that thing away and put on a factory or a Bursch setup.....or go with a Traid if you have 2.0 heatexchangers (not sure if they make 1.7/1.8 mufflers)
freezing14
May 26 2005, 11:18 AM
I do not have the heat exchanger, just some sort of headers, with a flange at the end
Mueller
May 26 2005, 11:21 AM
QUOTE (freezing14 @ May 26 2005, 10:18 AM) |
I do not have the heat exchanger, just some sort of headers, with a flange at the end |
at the end or ends??
if dual, you might have heat exchangers with the ducting removed....pretty common for rusty HE's
if the muffler you posted bolts up, you have modified heat exchangers....
a /4 header will have all 4 tubes converge into one tube
