He has a pointless module installed inside the distributor, also this injection system doesn't use trigger points.
Clark had a similar issue where his hot spark would start whacking out above 3000 rpm. I had him use a timing light attached to a random plug wire, and had him stare at this timing light as he manipulated the throttle cable. I had him repeat this test for every plug wire. I do believe his hotspark did fail due to a heak soak issues, either way it failed. If you repeat the test and see the same thing, your hotspark module has failed too.
I've become a believer with this group buy 123 distributor. It is a investment, but I think it is money well spent vs buying another hotspark module.
