QUOTE(type2man @ Dec 23 2017, 02:48 PM)
Check to make sure the linkage arms both come off the stops at the same time. You can do this by placing your finger where it comes of the stop on one side and looking at the other side.
Thank you! I tried this tonight and was able to detect that the right carb was coming off the stop before the left. The trick of feeling one while watching the other was the clue I was missing before.
I adjusted the linkage rod and got them much closer. And now the engine responds SO MUCH BETTER coming off of idle. Previously it was very rough when you just barely put your foot on the gas, and now it's great ... up until the next flat spot. I'm excited that I was able to make some progress.
I checked again with the air flow meters and observed it was much improved, but still far from perfect. I guess an experienced mechanic could get the linkage right without the meters. But for me they're fun.
Does anyone happen to know the wrench sizes of those CB Performance linkage rod lock nuts? Are they metric? I don't own many tools yet and I'm afraid of cornering them with my crescent wrench.
Also the linkage arm rods should have the same angle from the linkage to the carb base area, if not they will open at different rates.
Mine do not have the same angle, and I don't see how to adjust it. The angle on the right carb (the second photo) looks especially awkward to me.
Click to view attachment Click to view attachmentQUOTE(type2man @ Dec 23 2017, 02:48 PM)
Also it sounds like it running on three cylinders, check the idle jets and pump jets. Try lowering the idle half a turn at a time on each carb. I think what might have happened is that one linkage arm came loose and moved over and is causing the high idle by jamming the linkage arm. Both throttle arms have to be resting on the stops at idle
OK, I will look into this. It looks like I can still buy carb cleaner tomorrow.
As it arrived from previous owner, it starts instantly and idles at 800-900 when cold. When it's finally warm, the idle is way up there: 1200 or more.
