siverson
Nov 29 2017, 11:42 AM
I've probably done this 10 ten times in my life and never had any problem with it. But, I just got a new, OEM windshield rubber seal from Pelican and the metal "clips" are not compressed.
Normally when install these, I just lube up the sides and slide them on (done that and it was easy) and then push the horizontal piece onto the windshield and it's super easy. This new seal was not staying stuck at all, and when I peeled back the rubber (photo below) the metal "clip" is not compressed at all.
I don't recall ever having to compresses this metal part before. But, no problem, I tried compressing about 6" or so to test but I can't get it right. Either it is too compressed to fit on at all, or is too wide and doesn't stick on.
Any tips? What am I doing wrong here? I remember this piece being super easy to install...
-Steve
siverson
siverson
Nov 29 2017, 11:43 AM
sides went on fine
Socalandy
Nov 29 2017, 11:59 AM
that doesn't look OE to me based on the metal strip and the tabs look like their too long explaining why it wont stay in place.
My 2cents
siverson
Nov 29 2017, 01:24 PM
QUOTE(Socalandy @ Nov 29 2017, 09:59 AM)
My 2cents
hmmm... ok, thanks. I'll confirm with Pelican. It is advertised (and charged for - $261) as OEM...
-Steve
siverson
Nov 29 2017, 02:05 PM
>> The seals you have ordered are from the OEM supplier to Porsche.
>> We have sold 10 of these with in the parts year and have not had
>> any comebacks on these ?
>> Best Regards !
Hmmm 2... Pelican says definitely OEM. Anyone have a photo of the inside metal clips of another seal to compare to?
-Steve
Mikey914
Nov 29 2017, 03:27 PM
The OEM was NEVER a 2 part seal. If they sold to you as OEM, it may be the manufacturer, but not factory.
Mark
Mikedrevguy
Nov 29 2017, 03:51 PM
I just installed one of these and had to use a set of channel lock pliers to get seal to mate with the window frames.
If there’s an easier/other/better way, ???
Good luck.
Mike
siverson
Nov 29 2017, 04:38 PM
What do you mean by this? Is this "2 parts"?
-Steve
siverson
Nov 29 2017, 04:39 PM
The one on my green car that did press on ok looks to have a similar seam.
-Steve
siverson
Nov 29 2017, 04:43 PM
But the channel on the green car is tight and easy to take on an off.
-Steve
siverson
Hi Mike - did you push it on then use pliers once it was on the frame? Or before and then push/squeeze it on?
-Steve
Mikey914
Nov 29 2017, 05:06 PM
The factory part has the metal co molded into the channel. The no factory options have the metal folded in as it's cheaper to make that way. It also means that if it comes out of the fold it's dam near impossible to get back in.
I can say without a shadow of a doubt it is not factory.
