QUOTE(porbmw @ Dec 2 2017, 09:37 AM)
"someday" I plan on installing a 2.7 engine in the engine compartment of an engineless original 6
What engine shroud "fits" the 2.7?
can/do/should I use a shroud from a 6/or early 2.0/2.2/2.4 engine, or does the 2.7 engine require a shroud specifically from a 2.7
IF so, is there a "shroud color difference" from one 2.7 to another and..if so...which is preferred
Thanks
Paul
Someone is welcome to correct me but from memory the design changed for the 2.7,it may have something to do with the CIS and cooling fan size
,the cooling duct for the oil cooler was changed from memory.
I would tend to buy one that was supplied for your motor,you should pick one up for reasonable money,folks steer away from damaged ones but they can be easily repaired if cleaned properly before hand.
Early 2.7 (74) were black and the later ones green gelcoat.
