Transaxle removed from a 75 Porsche 914
Complete with axles, speedo cable, and clutch
This is the side shift version
Date code: HA08034 (March 08 1974)
$500 located in Kitchener, Ontario, Canada.
Note: This transaxle was removed from a running 914. Mileage is unknown.
I was going to use this transaxle behind a Northstar V8 project. In the making of my adapter plate, I also had to remove some material by the starter nose for clearance. You can clearly see the hole that I had to make. I also have two used clutches that you can have.
Shayne
