These are brand new, never installed - great savings at $50/pr +shpg. PM me if interested.
When I was setting up my car I bought 3 pairs of rear springs, installed the 225# springs and they've worked great so I'm passing on the others. The springs are 2.5" x 10" coil springs from Summit Racing and are powdercoated black. To install these on your car you will need a threaded spring perch to replace the factory stamped steel perch. The upside of this is that you have a big selection of spring rates and will be able to adjust ride height and corner balance in the rear.
These are links to the springs I have for sale.
175# - Summit RacingĀ® Coil-Over Springs SUM-102-5175
200# - Summit RacingĀ® Coil-Over Springs SUM-102-5200
