That is what you have to be sure of, and I am not. I'm new to 914s, so asking on the forum is best.
The standard 911 8x16 Fuch (911 361 020 45) has a 10.6mm offset.
The 944 Turbo 8x16 Fuch (951 362 117 00) is 23.3mm offset.
Thus the 911 wheel has a backsize of 112mm while the 944 has a 125mm backsize. So more of the 944 wheel is toward the inner body of the car than the 911 wheel.
A 944 8x16 is the widest OEM wheel than can fit under a stock 911 (69-89) front fender. (given enough camber)
Again, which wheel is correct for the 914, you need to ask on the forum.
Hope this is helpful.
Mitch
QUOTE(Nacho @ Dec 3 2017, 06:25 PM)
QUOTE(MitchRossi @ Dec 3 2017, 08:39 PM)
Nacho,
We were talking about my 944 8x16s..but they may not fit your needs. Because of the 23.3 mm offset, they may not clear the inner body of a 914.
Maybe someone reading this thread could answer that question. I used them on the front of my 1970 911.
best,
Mitch
I'm confused! I thought 23.3 offset is what 914 works best with? and the addition of the width would be 50/50 to the front & rear of the rim.
