Full Version: 73 914 2.0 Rebuild
Pages: 1, 2
R Dub
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture.
IPB Image
IPB Image
IPB Image
IPB Image
IPB Image
Olympic 914
Slantnose looks nicely done.
krazykonrad
The general consensus is that the original Bosch copper-core single electrode spark plugs are the best to use. I'm not sure of the part number, but they should be easy to find. I'd go with Bosch or Clewett Engineering wires.
Konrad
R Dub
QUOTE(krazykonrad @ Dec 4 2017, 10:18 AM) *
Konrad
Great. I will look into those
mgphoto
Beru another OEM supplier.
TheCabinetmaker
Most folks use ngk plugs and beru wires
R Dub
Just bought a set of Beru Wires and Bosch plugs from Pelican parts. Thanks for the suggestions. Now onto looking for a battery, fuel filter and oil filter. The current fuel filter on it is square and all the factory ones I see are circular shape so that tells me it is aftermarket. Also my Grandpa installed a additional canister oil filter which is aftermarket.
mgphoto
Battery recommendation AGM, no free acid, prevents hell hole issues.
Optima, Bosch makes one but the connections are in the wrong place.
R Dub
QUOTE(mgphoto @ Dec 4 2017, 05:01 PM) *
Thanks for the tip. I'll definitely look into an AGM battery
Larmo63
Those seats look like Scheels. Are they marked Recaro?
burton73
QUOTE(Larmo63 @ Dec 4 2017, 08:11 PM) *
Look at my Scheel welcome.png logo on my seat. A little different shape?
Bob B
R Dub
I was told by my dad and Grandpa that they are Recaro's but I will take a second look cause the seats do look similar.
Also I see Duracell has a AGM battery that the terminals look correct on from Batteries Plus. Anyone have any experience with this one?
R Dub
Update. Actually got the car running to day. First time it ran in 18 years. And really it didn't take make to get it to go. Drained all the old oil and fuel out of it. Had to rebuild the electric fuel pump. Had to take off and clean out one of the carbs, had to change the plugs and wires, new battery and it started. Super excited. Still more to go but knowing that ir ran is amazing.
burton73
It there snow on the ground there.
Stay dry my friend!
Looking good
Bob B
burton73
This is a Konig driver's seat, but sure looks a lot like a Scheel 401/501, except for the leg bolsters
I looked up you seats and I think they are Konigs
Round logo.
There are great seats.
Porschef
I've got the same wheel on my car, your horn button looks to be in nice shape. beer.gif
R Dub
QUOTE(burton73 @ Feb 17 2018, 10:05 PM) *
Round logo.
Thanks for the input. The logo on both seats are so busy worn that I can't see them. I will look into Konigs.
R Dub
QUOTE(Porschef @ Feb 18 2018, 08:22 AM) *
I absolutely love that wheel. Yeah it is in great shape
R Dub
Looking for some parts advice.
1. Right under the engine hatch there is a black plastic funnel that a house connects to bring water out of the engine bay and under the car. Both the funnel and hose are melted on the drivers side. Any idea where I can get new ones?
2. The car has duel Weber 44 carbs in it. The air filters that were on it looked to have come from a dune buggy as the cover said Claude's Buggies on it. They are oval and measure about 7" long x 4" wide x 3.5" tall. Any idea where I can get new air filters?
fishgeckos
I like the rear spoiler.
R Dub
A couple of questions. As I mentions this car does have dual Weber carbs on it. Anyone know of a place that specializes in Weber carbs that I can have them sent to be rebuilt?
Also you have to pump and hold the brake pedal to get any sort of pressure. Once the pressure is there, you can hold the pedal firm, it does not move. However as soon as you release the pedal you have to pump them again to get the pressure back. I know I need to do a complete flush of the fluid since it is 30 years old but anything other ideas what could be causing this?
R Dub
Just a quick update, I found a place in CA called JayCee Enterprises that specializes in Weber carbs so I sent them there. I'll update this post later with the quality of their work once I get them back.
Also I flushed the brake fluid out with new stuff and that worked wonders. I now have always have a firm pedal, no more having to pump it.
Once I get the carbs back, I can put them back on the car and hopefully at least drive it around the block. Still a decent ways to go until it is complete but it's getting there, can't wait.
R Dub
Haven't posted in a while cause I haven't touched the car up until yesterday when I drove it for the first time ever which was AWESOME smilie_pokal.gif
Finally got some time so my dad and I got to work on the car. First started out by fixing the one rim that had a slow leak on it. Had to have a shop dismount the tire then take it apart, clean it up and re-silicone it then have it remounted.
Then had to put the carbs back together and put back on the car. Wasn't thrilled with the company I sent them to as they did not do what they said, it took double the amount of time, charged me ~$200 more than quoted and he sent them back in pieces instead of together.
Went to start it only to find out the fuel pump died so had to go buy a new one and spend some time at the hardware store to get the new one plumb like the old one to use the same mounting points, hoses, etc. Once we got all of that figured out, the fuel pump wouldn't turn on with the key for some reason. Will have to look into that more as we are getting 12V to the positive wire and it is grounded. We used a jump box to bypass it and it works so I drove it around the block a couple of times. It was an truly awesome feeling.
Still got a while to go until it is "done" but it's almost road worthy again!
rjames
QUOTE(R Dub @ Jun 19 2018, 11:43 AM) *
Fuel pump- check the relay on the relay board in the engine compartment. All the relays are the same so you can swap the existing ones around to find a good one (assuming there's a good one to be found).
rhodyguy
Go to the classic thread forum. The easy method to power your FP is detailed in a thread there. Real easy.
R Dub
Got the fuel pump figured out but found out that oil was leaking out of the push rod tubes and 3 of 4 cylinders had low compression. One was as low as 60 psi. So we pulled the engine out and pulled the heads and cylinders off. Found a few issues. First is a couple of the push rods are bent and the second issue is the cylinders have some scoring on them which we believe to be from rust as the car sat for 20 years. Now a few questions (and sorry for being a total nub):
1) Where can I find new push rods. I've searched Google and all I can find is new push rod tubes, which I'll get as well, but not push rods.
2) Anything I can do to a 2.0L to gain some performance? I'm looking for more bolt on stuff, not looking to machine the block or heads or anything like that. I've read something about a 2056? Is this just bolting on bigger cylinders and pistons while leaving the crank, rods and head all stock?
3) I'm going to replace the alternator belt and some grommets while it's out. Anything else I should replace while the engine is out?
Mblizzard
QUOTE(R Dub @ Nov 11 2018, 05:35 PM) *
You can go the AA Piston route for P/Cs for about $400. You will see some improvement but unless the cam has been swapped you wont get the most out of the upgrade.
My suggestion is until you are ready to split the case, fix (hone and new rings) the current P/Cs and change to modern FI. You van tune the modern FI to get eh most out of the existing 2.0 and use most of the existing parts.
R Dub
QUOTE(Mblizzard @ Nov 12 2018, 10:19 AM) *
Thanks for the reply. When I was looking for P/C, it looks like AA Pistons was really the only company out there. Does anyone have any experience with them? Are they a good company? Have a good product?
Does the case have to be split to swap the cam? And what cam is recommended if I were to go with 96MM pistons?
I was told the Weber carbs were put on because the FI of the day was bad (Maybe it's just cause no one knew who to work on FI back then confused24.gif) Is there a compnay that makes a modern FI for the 914 or is it all stock stuff
Tdskip
Good morning. Not to discourage your asking questions on the forum but there is a TON of good info on your inquires available by searching. They are common topics of discussion and you can review other members builds on other FI systems, troubleshooting the original FI and engine build/part recommendations.
Looks like you are making progress, keep pressing on!
TheCabinetmaker
What Td said. Do your search on Google, then add the name of this site.
Mblizzard
QUOTE(R Dub @ Nov 12 2018, 11:49 AM) *
Yes the case does have to be split to replaced the cam.
There are others P/Cs out the like the Type 4 Store if you want the best, but AA is a reasonable product that is inexpensive. But you do get what you pay for.
The recommended cam will be based on what you want the car to do. For a good overall street car I would go with the Web cam 86. Also understand that just installing the cam is the beginning, there are a number of other things that must be done to get the best performance like making sure your valve train geometry is correct. Too often people install a cam and don't see all of the performance it has due to incorrect valve train geometry. Do a search it will bring up lots of good reading.
When the FI is replace by carbs it is rare that the cam is changed. So I would guess you have a FI cam in the engine.
I think McMark of Original Customs is still making a turn Key Micro Squirt system.
bbrock
And make sure you are settled on your fuel system before you decide on the cam.
I did just as OP mentioned earlier. Got tired of the FI leaving me stranded and wrenching on the car in parking lots and highway shoulders. Didn't have a clue how to properly work on the FI, no Interwebs at the time to teach me how, couldn't afford to have someone else work on it and probably couldn't find a competent mechanic if I did. So I did what all the cool kids were doing and bought a pair of Webers and installed a carb cam. Thirty years later, I still haven't finished the rebuild so the Webers have never been used. I'd kind of like to refurb the stock FI but it isn't worth splitting the case to swap that cam out. So I'll run the Webers and see how I like them and will leave the FI for a future project.
BTW, I really liked my stock 2 liter so went back with OEM 94mm jugs but opted for the higher compression euro spec flat tops just to juice it a little bit.
R Dub
I'm going to keep the car with the dual Webers on it. It is currently setup for it and I know it runs with them, not to mention I just spend a decent amount of money to have them rebuilt.
As far was what my plans are for the car, It is going to a street car. Something to take to work on a nice Friday or out to dinner. It might see a rare track day but I own a sport bike that I track sometimes. So I am looking for the car to have decent performance but needs to be reliable. Since I'm already this far into it, I want to do it right the first time and be done with it so I can enjoy it for many years to come.
Since the motor is already out and this far apart, I will split the case to replace the cam to make sure it is right. I will definitely look into Web cam 86. I will also do some research on the valve train geometry to make sure that is correct. I will be back if I have any questions.
I did see that McMark was selling motors for $5K-$5500, not sure if he still is. I'm very tempted to do that but fear the wife might sign the divorce papers as she wasn't happy that I got the car in the first place. I see the type 4 store has a kit but it's $9K. A little out of budget.
I really appreciate all the help guys.
R Dub
Engine out
IPB Image
Got the engine disassembled down to the case for the most part.
IPB Image
Noticed that the lifters are bad. One was missing the retainer spring as per the picture below. This just so happens to be the same cylinder that had a bent push rod. Coincidence, I think not.
IPB Image
Now I need to buy some parts so I can split the case replace the cam and start the rebuild process. Some questions I was hoping you guys can help with:
1) My dad's cousin (whom I've never met) works on air cool VW for a living. He said to keep the motor at a stock 2.0L. Other than keeping with originality, is their any reason to do this and not increase to a 2056? Cause I can't see one
2) Assuming going with a 2056. I'm thinking about going with Web Cam grind# 86 as I've read that is a good cam to run with carbs. And would then go with hydraulic lifters. Thoughts?
3) Do I need to change out the Cam gear for any reason or can I reuse the old one assuming it is not broke or worn too much?
4) For P&C's, I was thinking about going this route from Fat Performance. Any one have experience with this?
Any other suggestions or advise?
steuspeed
No reason to stick with 2.0L. Go for more power. I like your P/C choice, but others with more experience will chime in.
marksteinhilber
QUOTE(R Dub @ Feb 19 2018, 07:50 AM) *
Funnels can come from 914rubber, an excellent vendor listed on this site. The air filters for the dual webers are available many places including CB performance, Pierside parts, and other Vdub vendors.
mgphoto
Pull the oil pump, look inside, if the cam gear has rivets it is original FI cam, if there are bolts could be aftermarket carb cam.
mgphoto
Hydraulic lifters, bad...
mgphoto
1 motor is no longer stock, if it was then yes leave it stock as in D-Jet
2 check the type iv store for cam types
3 yes, riveted gears need some machine work for use with new cam.
4 these are fine, they might transfer heat a little better then the AAs.
Dump the hydraulic lifters...
R Dub
QUOTE(mgphoto @ Jan 10 2019, 05:21 PM) *
1. Motor and car are very far from stock so not concerned about originality. I'll build a 2056 then.
2. Will do. Thanks
3. Did not know OE cam gears were riveted. I will check that. Thanks for the info. Is so I will get a new cam gear as well.
4. Thanks for input. I appreciate it.
Why are hydraulic lifters bad? What lifters would you go with?
mgphoto
QUOTE(R Dub @ Jan 10 2019, 04:39 PM) *
2. Will do. Thanks
I built mine with parkerized solid lifters and hand cut a set of chrome moly push rods.
I also used 911 adjusters.
I keep the D-Jet.
Hydraulic lifters steal horsepower, they can collapse and cause a push rod to bend.
Better for buses than sports cars. They need a hydraulic cam.
R Dub
QUOTE(mgphoto @ Jan 11 2019, 01:37 PM) *
I keep the D-Jet.
I understand that hydraulic lifters might rob a bit of power as they can compress compared to a solid lifter. However the lift on the hydraulic cam is a bit larger which should account for some of this no?
I'm more interested in building a reliable street motor than a all out race motor. From my understanding with solids you need to adjust the valves more often and with hydraulic you do not correct? So if I'm looking to go with the "less maintenance" route, isn't hydraulic the way to go?
Now sorry to be a total nub but I've read a lot about people going with "1.7 rockers" and "911 adjusters" and have many questions about this. I've done a lot of searches but haven't found a clear answer
1. Are these rockers with a 1.7:1 ratio or rocker arms off of a 1.7L motor?
2. Do you have to do any machining/anything other parts to install 1.7 rockers into a stock 2.0L head
3. Is there any specific year and engine size 911 that I need adjusters out of?
4. What is the benefits of going with this route?
5. If I do go with hydraulic cam/lifters, is there still a benefit of going with these?
bbrock
There are several threads on the swivel foot adjusters. I think this one should answer most of your questions: except the last one: http://www.914world.com/bbs2/index.php?sho...327102&st=0
R Dub
QUOTE(bbrock @ Jan 12 2019, 11:10 PM) *
Thanks so much for the reply. This does help, not sure why I couldn't find this in my initial search.
It does look like you need to cut the rockers down in order to accept the 911 adjusters. To be honest I don't really like this idea. Also right now I Plan on going with the stock valves, not SS and if this car see 2000 miles a year I would be surprised. Based on what I've read, the stock 10MM adjusters should do the job just fine for my application so I will most likely go that route.
R Dub
Just found this on aircooled.net about the 911 adjusters
"IMPORTANT! Do NOT use these on hydraulic lifter engines, THEY CAN FAIL. These need "valve lash" to give oil the chance to get in there and lubricate, with no clearance they can gall and fail quickly!"
Good to know
mgphoto
My advice is that you should pick up the Wilson VW engine rebuild book.
Build a stock engine with 96mm barrels.
Get a good carb cam, solid lifters and stock push rods.
Your gonna need a machine shop to measure your case, grind valves and make other checks to insure a quality build.
Toss out the 40 year old valves, new stainless will work great.
You don’t need much to make a type iv a little peppier.
It will be a really fun car to drive.
FYI the adjustment schedule is the same for solid lifters and hydraulic.
Elephant feet with chrome moly push rods will produce “0” lash meaning you don’t use a feeler gauge so you only need 2 hands instead of 3, to adjust the valves, but a lot more complicated to build in the first place.
R Dub
Just ordered about $630 worth of seals from 914rubber. Hopefully the car will be all sealed now.
Got to look at the heads just a bit yesterday. Found out the adjuster screw on the rocker is 8MM and not the stock 10MM. Not really sure why though.
IPB Image
Also not sure if this is a issue or not. Really hoping not cause buying new heads was not in the budget. I'm going to contact a local shop tomorrow to see if they can inspect and rebuild if possible.
IPB Image
IPB Image
Bleyseng
QUOTE(R Dub @ Jan 12 2019, 03:19 PM) *
I keep the D-Jet.
Hydraulic lifters wear the cams out as they are always in contact. Solids have the .006 lash so they do have a time no in contact hence better wear. If you ever looked at the high mileage buses and vanagons with hydraulic lifters you would see the cams wiped out. Plus the cam grinds are for buses/vans not a 914. I check adjust the valves once a year when I change the oil. I drive mine maybe 1500-2000 miles per year so I still change the oil and check things.
Valy
That crack needs some head welding.
Sorry for the bad news.
R Dub
Quick update:
The heads are with Adrian at Headflow masters. He called saying they are repairable and will do a complete valve job including new stainless valves, springs, guides and seats. He said the SI valves he uses will work well with the stock adjuster screws. He suggested going with bigger valves, 44x38, since the car is running carbs so that will be getting done as well.
Just ordered 96mm Keith Black piston and cylinders from FAT Performance along with a new 86 grind cam, solid lifters and a new cam gear from Web Cam.
Will be ordering the rest of the stuff such as bearings, gaskets, seals, clutch, push rods, etc very soon. Hope to have all the parts arrive within a couple of weeks so I can start to rebuild. I did pick up the Tom Wilson rebuild book so hopefully it goes fairly smooth. I'll post pics of the new parts and progress as soon as I get them.
Invision Power Board © 2001-2024 Invision Power Services, Inc.
