914 Ranch
Dec 7 2017, 04:24 PM
Got this 3.0 not sure of the year and think that the alt has an external regulator (small black box with 3 wires). Blue, black and brown. I believe that the blue one gets put with the blue from the alt. Where do the black and brown go? One should be a ground.
914 Ranch
Dec 7 2017, 04:36 PM
I'm thinking black is ground and brown is going to the white. I remember a white wire coming out of the alt.
Now I'm going to go look for the white wire
914 Ranch
Dec 7 2017, 06:04 PM
White wire is coming from the coil. Wires coming from the alternator​are red, blue and black.
I'm thinking brown is ground.
Only theory.
914 Ranch
Dec 8 2017, 04:40 PM
Almost 100 views and no response.
What I need to know is where the wires go from the 6 pin on the ignition module and the 3 wires from the external regulator go.
914 Ranch
Dec 8 2017, 04:44 PM
914 Ranch
Dec 8 2017, 04:47 PM
Mark Henry
Dec 8 2017, 04:55 PM
Ummm...isn't that a CDI?
GeorgeRud
Dec 8 2017, 05:04 PM
I thought the 3.0 liter engines used an internal voltage regulator. And yes, the ribbed box is a Bosch CDI.
Mark Henry
Dec 8 2017, 05:05 PM
If you look carefully at the regulator connector it's marked (DF, D+ and D-) it corresponds with what's on the alternator. The connector MALE on the reg.
My wire colours are below, but no clue if it's the same as yours. (note this is looking straight on the male connector on the reg.)
D-, brown
DF, black........................ D+, red/black stripe also has green/black stripe to idiot light
Mark Henry
Dec 8 2017, 05:13 PM
On some 911 alternator's, D+ is marked 61+....it's the same thing.
Internal reg should only have B+ and the idiot light connection.
IronHillRestorations
Dec 8 2017, 05:25 PM
Can you post a pic of the back of the alternator?
Do you know for sure what wires are definitely coming out of the alternator?
Is the 3.0 always been in the car, or is it a
All the 3.0's I've made harnesses for have had alternators that are internally regulated, but it's entirely possible that someone put an externally reg'd alternator.
In the 1st post, there's a voltage regulator mounted above the CDI box.
Dec 8 2017, 05:27 PM
Is the 3.0 always been in the car, or is it a new install?
Mark Henry
Dec 8 2017, 05:31 PM
Another crazy 911 alternator point.
Your alternator may have two B+, two DF and two D- posts, but only one D+ (61+) post.
Just wire up one post of each only!
Don't try to jump B+ to B+, etc. as it won't work.
I have no clue why the doubles and either one will work.
Mark Henry
Dec 8 2017, 05:33 PM
External reg will look like one of theses two: I have the one on the left.
914 Ranch
Dec 8 2017, 08:31 PM
I'll pull the fan cover tonight and take a picture cause I think the alt and the fan came from another motor. It has some broken blade's. This hole thing ran 2 weeks ago. I had to change some wires and now I'm going not putting it back correctly. Pic of the illegitimate external regulator.
914 Ranch
Dec 8 2017, 08:34 PM
It plugged into a plug and the wires change color but the engine side of the connector is Porsche.
The ignition module is causing me problems too.
914 Ranch
Dec 8 2017, 08:54 PM
About to change the bus bar in the engine bay and tried to start her before I pull the wires and put them into the box.
Click to view attachmentShould have taken a picture before...
Mark Henry
Dec 8 2017, 09:09 PM
I've been told that a regulator is a regulator, but the the guys over on the bird swear you have to use a matching regulator. Bosch alt so bosch reg.
I had similar issue a little over a month ago, had both the alt and reg tested and they were OK. It worked when I tried the 2nd time.
Older guy at the shop, I gave him two bosch regulators I had, one mechanical and one electronic, he said they both worked but he prefered the mechanical.
Mechanical are the ones with the bigger case.
914 Ranch
Dec 8 2017, 09:15 PM
It worked fine before I fucked with the car. The box up front works fine.
Click to view attachmentI just have to get the connectors linked together correctly.
914 Ranch
Dec 9 2017, 12:03 AM
This car has to be my daily driver. We just got 1.86" of water in 2 hours. I installed this 2 days before Irma. We had 31" before that makes over 60 for the year. Sometimes driving the car is going to be wet.
914 Ranch
Dec 9 2017, 05:01 AM
When I put the engine in the car in 09 the CDI and external regulator came sitting on top of the motor. Motor would not start, injection problem. Put carbs on and it had over 100 A/X laps. Always started right up. Car only had idiot lights and a tach. Now has all lights and indicators on the dash and an air horn.
When I did the box up front I needed to change some wires and took part of the wires off the bar in the engine bay. Big mistake.
The CDI gets its ground at the bracket for the coil. I'll check that. I needed to run a new wire for the starter, so the wires on the engine got changed.
The CDI gets its power from a dedicated relay turned on by the ignition switch. It has power.
I'M SO FUCHEN CLOSE....
914 Ranch
Dec 9 2017, 07:12 AM
OK, so I looked at the alternator and the wires coming out of it are red, blue and black. The plug from the external regulator are blue black and brown. I hooked it up blues​, blacks, red to brown.
The CDI has power to it but the coil has none. The ground for the CDI at the coil is good. I'll check the connectors.
914 Ranch
Dec 9 2017, 07:26 AM
Not correct. The brown to + turns off the red idiot light. Now I'm going to try to ground it.
914 Ranch
Dec 9 2017, 07:35 AM
Dose the CDI produce power at the coil when the key is in the on position?
Mark Henry
Dec 9 2017, 12:27 PM
QUOTE(914 Ranch @ Dec 9 2017, 08:35 AM)
Bob Ashlock is a good guy and would tell you what values you should see on the CDI.
Sure he's hoping for a sale down the road, but he's a helpful, no BS guy. He charges $200 for a CDI rebuild.
914 Ranch
Dec 9 2017, 04:25 PM
Thanks Mark, I'll check him Monday.
