Calwaterbear
Dec 9 2017, 06:34 PM
Ok so I'm replacing the throttle cable, when it comes out of the firewall, the previous owner has it routed up through a small hole on the right (passenger side) near the hell hole.
Can I assume that is correct?
thanks
flmont
Dec 9 2017, 09:25 PM
I would think so plus should be secured along the way.in a couple places
914Sixer
Dec 10 2017, 07:41 AM
Should be in a rubber grommet in the center of the right side sheet metal corner.
bdstone914
Dec 10 2017, 09:00 AM
QUOTE(Calwaterbear @ Dec 9 2017, 06:34 PM)
thanks
Can you post a picture of how yours is routed ?
simonjb
Dec 11 2017, 11:58 AM
Anyone have a picture? I have the same question
IronHillRestorations
Dec 11 2017, 02:27 PM
The stock grommet is in the right engine tin, basically centered in the square area adjacent the front and side engine shelf areas.
simonjb
Dec 11 2017, 02:50 PM
ahh, ok - so through the tin attached to the engine - not through shelf. Thanks
simonjb
Dec 11 2017, 02:55 PM
So the hole to the bottom left of the Coil?
ChrisFoley
Dec 11 2017, 03:05 PM
QUOTE(simonjb @ Dec 11 2017, 04:55 PM)
The stock location works for factory efi but not so well for carbs.
Better to come up between the tin and engine shelf, and then maybe put a fresh hole in the tin once you see the most favorable routing.
SKL1
Dec 11 2017, 04:34 PM
Agree with Chris if you have carbs. Too many sharp turns with the route for FI.
You might want to consider his linkage too...
simonjb
Dec 11 2017, 06:31 PM
Great. Thanks
Dec 11 2017, 09:23 PM
FWIW, I've always wanted to make a bell crank linkage that allowed the stock cable routing for carbs. Not that it matters.
