QUOTE(Cal @ Sep 15 2020, 09:42 AM)
@horizontally-opposed I never purchased the Maxilite rims....I ended up keeping the original fuchs on my car.
Thanks, Jeff / @Cal!
Any chance you can check in with your friend to see how they're holding up a few years later?
QUOTE(porschetub @ Sep 13 2020, 04:01 PM)
Pete you can't go wrong,very happy with the 16's I bought,nicely made and my tire guy (30yrs experience) was impressed with them,with new tyres they balanced with minimal weights.
Not sure about weight,I thought they were a bit heavier than genuine but not 100% on that.
I would prefer 15'' as I like the look better,the importer didn't have any 15's so got the 16's,needed wheels @ the time as my car was on space savers.
For pure function, I'd definitely go 16s—for the tire choices alone. Also like the look on some 914s. Sadly, I have the 15-inch bug when it comes to my own 914, so my choices are stick with the current deep 6s (likely) or move to a set of Maxilites with custom finishes. The motivation is a desire to mount 215/60R15 rear tires with the massaging necessary to get them in there.
The Maxilites are pretty close in appearance—only thing I really see is the lip that the center cap is supposed to cover is thinner, and you lose some of the cool detail (that wasn't meant to be a detail) inside the wheel if you run without caps (which I prefer). My alternatives is to either have Harvey widen my rears, or find a set of true 7Rs, which is in the high $,$$$ range. Or move to 205/60s all around if I can find a tire I like. Not in any hurry, but would like more rear tire and looking to have a plan for when these Avons age out in a year or so.
