Fatboy007
Dec 20 2017, 12:05 PM
So yeah...75 fi...Smell gas when running. Does the fuel line run along the center section with the linkage?
designerguy90
Dec 20 2017, 12:08 PM
Yes. The feed and return lines run in the center tunnel. Assuming they are still the original plastic lines, its probably time for them to be replaced. The stainless steel line set from Tangerine Racing is fantastic, and is a fairly easy install, though my engine being out at the time probably helped matters a bit.
mzalanka
Dec 20 2017, 12:38 PM
Def check send & return lines in the tunnel. Don’t drive until you rule out a leak in the engine compartment. Check fuel line connections in the engine bay to the return lines and FI rails. Also check injector seals including cold start valve at plenum.
If you can smell it in the cabin though it’s probably a front trunk issue. Check rubber fuel line connections under tank in the front trunk (accessible from underneath pass side - need to jack up & remove gravel shield).
Also possible/probable the emission canister/hose is removed and the tank is venting to the front trunk.
Fuel tank cap might not be completely on; gasket could be missing/cracked; gasket from plastic expansion tank to tank also could be missing or cracked.
Mikey914
Dec 20 2017, 02:14 PM
Look underneath the car see if you see something dripping more often than not it's in the very front section where the fuel filter is in the pump.
Coondog
Dec 20 2017, 02:20 PM
euro911
Dec 20 2017, 03:18 PM
Don't overlook the hoses from the fuel tank to the fuel pump Under the tank.
Steve Snyder
Dec 20 2017, 03:52 PM
Assuming there is not a puddle of gasoline under your car, the first things I would check/replace are the short line from the gas tank to the evaporation tank, the vent line from the evaporation tank, and the tank filler gasket. Failure of any of those items leads to gas fumes in the cabin when running, and they are much simpler to replace than the fuel lines in the tunnel (although replacing 40+ year-old plastic lines that carry gasoline through the cabin of your car is a good idea regardless).
Dave_Darling
Dec 20 2017, 09:53 PM
Does the front trunk smell of fuel? If so, and the hoses under the tank are OK, you may have pin-holes in the tank. The tank partly sits on three felt pads glued to the inside of the compartment, and they have been known to trap water and lead to pinhole rust-through.
--DD
forrestkhaag
Dec 20 2017, 10:25 PM
Or how about the expansion tank and/or the fume canister may spent. Is it a smell on hard cornering to the left? Several things can contribute but the above advice is all good / replace plastic lines with SS (cheap at Pep Boys) and all things-gas in the engine bay. Drive Man, Drive!
Fatboy007
Dec 20 2017, 10:38 PM
Thanks folks... I'm gonna check it out tomorrow... What an awesome community
ndfrigi
Feb 15 2018, 04:57 PM
ooops sorry Stacey! old thread or last December thread of yours. All fuel lines replaced and has the SS tunnel lines and at the engine bay. Did you find where the smell is coming from? I hope just the charcoal canister since I didn’t refill it with charcoal.
ValcoOscar
Feb 15 2018, 06:10 PM
Stacey-
You, or you and Noel are welcome to use my 2 post lift in OC should you need to. Just saying
Just PM me
Oscar
ndfrigi
Feb 15 2018, 06:55 PM
QUOTE(ValcoOscar @ Feb 15 2018, 04:10 PM)
Stacey-
Just PM me
Oscar
Thanks sir Oscar!
larryM
Feb 17 2018, 11:35 PM
X2 - look hard at the vapor lines & connections at the tank/canister
very common problem - many old threads on this
- we are all asssuming that all of those are still intact as oem? (not common)
QUOTE(forrestkhaag @ Dec 20 2017, 08:25 PM)
