I’ve searched for 3 hours and cannot find the polarity of this Bosch in-line fuel pump. The terminals are not labeled positive or negative, only a smaller M4 terminal and larger M5. Which one is positive and which is negative?
For chassis wiring - the (EDIT) brown is ground and black/red is positive, correct?
finally, if I locate the pump to the trunk, how do I back track the wiring from the engine compartment to the trunk? it still needs to go through the relay which is in the engine bay
