QUOTE(wndsrfr @ Dec 23 2017, 12:25 PM)
QUOTE(hseymore1 @ Dec 23 2017, 08:45 AM)
I installed a new alternator and voltage regulator. I was told that you did not have to do anything to the new alternator to get it in charge mode, but I am only getting 12.5 volts output. Voltage regulator is good. Any suggestions of recommendations
Check the bulb in the dash....it may be part of the circuit to excite the alternator..
Assuming your alternator and VR are good, it sounds like you're not getting the alternator going. The armature (rotating part) needs current through the GEN light on the dash. Make sure the GEN light lights up when before cranking.
And as mentioned before, measure voltage across the battery. The VDO gauge can have significant voltage drop WRT the battery voltage.
