simonjb
Dec 23 2017, 07:31 PM
Had the car repainted and am now in the process of reassembling. I am surprised by the amount of time it takes to put everything back together...put new SS line and fuel pump for the 2.3.
Click to view attachmentClick to view attachment
Dec 23 2017, 07:47 PM
Looks great. Take your time and enjoy.
Lucky9146
Dec 23 2017, 07:59 PM
QUOTE(simonjb @ Dec 23 2017, 05:31 PM)
Click to view attachmentAlways fun working with clean parts and an amazing looking paint job! Look at the finish on the back of that fire wall.
Kinda jealous of the floor too....
I want one.
Like Mark says enjoy!
saigon71
Dec 24 2017, 12:24 PM
Beautiful work!
Complete agreement on the amount of time to reassemble.
You are approaching the finish line!
simonjb
Dec 31 2017, 01:13 PM
So- It doesnt look like much - but I spent hours going over the wiring harness cleaning and re-taping. But there is progress!
74ravenna
Dec 31 2017, 02:03 PM
Wow, that looks great.
That is a lot of excellent work.
1) What are you going to put on the floorboards for insulation/sound deadening?
2) How did you clean and rust proof the inside of the center tunnel and inside the longs?
Thanks
rgalla9146
Outstanding plumbing.
Beautiful work.
I'm in North Jersey with a newly painted GT conversion chassis waiting for
my attention.
Keep up the good work !
simonjb
Dec 31 2017, 03:01 PM
QUOTE(rgalla9146 @ Dec 31 2017, 03:03 PM)
Beautiful work.
my attention.
Thanks - looking forward to seeing your build
Specracer
Dec 31 2017, 04:39 PM
I see your in CT, so the weather here in the northeast will likely keep you from being able to drive it for several months, so you have some time.
Works looks great, enjoy it!
simonjb
Jan 1 2018, 12:53 PM
A little bit more progress = installed the pedal cluster and gear shift.
However, I have this small round flexible rubber bushing left over? near front of photo.... I thought it might be for the accelerator ? But can't seem to figure out where it goes?
Mikey914
Jan 2 2018, 02:30 AM
Wow nice work.
simonjb
Jan 2 2018, 08:23 AM
QUOTE(Mikey914 @ Jan 2 2018, 03:30 AM)
Wow nice work.
Thanks - But to be truthful - I owe a lot to many folks on this forum without whom I would still be trying to figure out where to start! The advice and help on here is outstanding.
simonjb
Jan 19 2018, 03:19 PM
So a small bit of progress - but even after being in my freezer for a week it took some serious effort!
simonjb
Jan 27 2018, 01:02 PM
ok, a bit more progress - installed by refurbished PMB calipers ....
mtndawg
Jan 27 2018, 10:11 PM
Looks better than a new car.
pete000
Jan 27 2018, 10:14 PM
NICE !
burton73
Jan 27 2018, 11:08 PM
Sweet.
Mueller
Jan 27 2018, 11:22 PM
So nice and clean!
aharder
Jan 27 2018, 11:32 PM
Nice Job
76-914
Jan 28 2018, 09:40 AM
Is there an envy icon?
simonjb
Jan 29 2018, 07:53 PM
I finally decided that I should replace the vinyl on the sail and roll bar. I debated leaving it - but given I’ve refreshed everything else, I decided to go ahead. Stage one was removal of the old vinyl...not bad underneath after 40 plus years!
simonjb
Feb 3 2018, 03:33 PM
Ready to cement the new Sail and cross-beam from 914Rubber
aggiezig
Feb 4 2018, 12:25 AM
Your progress is inspiring me to push forward. It must be so nice to work in a shiny, new, clean engine bay. I'm jealous!
defianty
Feb 4 2018, 03:15 AM
Car is looking fantastic. I can't wait until this part in my build, I've got boxes stashed of new parts ready to install and a big order on its way from 914rubber right now.
Keep up the good work and looking forward to more updates.
simonjb
Feb 4 2018, 02:52 PM
Commenced work on the front bearings and brakes today...
gothspeed
Feb 5 2018, 09:43 AM
Click to view attachmentClick to view attachmentNice fuel pump install! I was thinking to mount it in that general area. What did you use to mount the fuel pump? Threaded insert into panel? Does the filter have a 'mount' to firewall?
simonjb
Feb 5 2018, 11:42 AM
QUOTE(gothspeed @ Feb 5 2018, 10:43 AM)
I must send out kudos to
Chris at Tangerine[u]. He came up with the mounting and has the parts to make it all come together. I mounted the pump with a bolt and nut all the way through the firewall. The filter "hangs" , but its not going anywhere.
simonjb
Feb 5 2018, 11:49 AM
So, after fretting about how hard it could be to mount the front hubs, I managed to do both within an hour.
I removed old bearings and ground down the outer edges to use as a punch. Froze the races overnight and got all 4 of them seated nicely with some gentle guidance - made sure they all set perfectly. Placed the new well greased up bearings in and she went right on to the spindle! I was worried because the old ones were stuck on very tightly. Tightened the nut up and then slack off a 1/4 turn, then hand tight while rotating the wheel. Then new caps.
simonjb
Feb 5 2018, 04:29 PM
Started on re-doing the vinyl. It really takes some time to make sure you don't mess it up! Cutting the bottom of the sail was scary
Old vs New and partial install..
gothspeed
Feb 5 2018, 04:59 PM
QUOTE(simonjb @ Feb 5 2018, 09:42 AM)
car looks great! thanks for the info on the fuel pump install
simonjb
Feb 10 2018, 12:59 PM
Finally managed to finish the new vinyl. Not a hard job, but finicky and time consuming.
simonjb
Feb 19 2018, 10:23 AM
The dash is finally coming together. Gauges are at NH speedometer getting a renovation and should be back soon. I'll finish the wiring when I install the battery and make sure that all is ok.
defianty
Feb 19 2018, 10:41 AM
Beautiful clean and top class work.
Mikey914
Feb 19 2018, 10:46 AM
First class work.
That little rubber bushing is probably the e brake sleeve.
simonjb
Feb 19 2018, 11:42 AM
Thanks guys. Its time consuming, but very rewarding. Now I know why it costs so much to have it professionally done.
Feb 19 2018, 12:34 PM
QUOTE(simonjb @ Feb 19 2018, 12:42 PM)
Looks great!
When we build from the ground up at the shop, it always seems like it should go together much faster but it doesn't.
effutuo101
Feb 19 2018, 10:45 PM
There should be!
simonjb
Feb 22 2018, 11:35 AM
I have been slowly restoring my 1974 with about 38,000 miles on the clock. As you can see below, I've stripped it all the way down. I am also re-thinking if I should also replace the front and rear shocks? The rear ones are BOGE and look original. The car only has 38,000 miles, but it is over 40 years old...plus would it be easier now than latter?
Comments?
barefoot
Feb 22 2018, 12:39 PM
QUOTE(simonjb @ Feb 22 2018, 12:35 PM)
Comments?
Easy enough to strip them down (borrow a spring compressor from your local FLAPS)
then clean & repaint you can test the shocks to see if still good then.
n2j2ryan
Feb 22 2018, 01:45 PM
Thanks for the Pics. I am a couple of months behind you so am storing some of your photos!!!
Is that a Tangerine Fuel kit?
Thanks
Neil
simonjb
Mar 2 2018, 12:13 PM
A bit more progress..Engine work..
Added the Taco plate cover and ran the wire
Added the red seals from 914 Rubber to the heater connections
Click to view attachmentClick to view attachmentClick to view attachment
rhodyguy
Mar 2 2018, 12:16 PM
A+ on the duct gaskets. Every bit of sealing helps. AM seals elsewhere are cost prohibitive.
simonjb
Mar 27 2018, 06:18 PM
simonjb
Apr 21 2018, 01:27 PM
raynekat
Apr 21 2018, 05:42 PM
Really nice.
Everything looks great!
simonjb
Apr 21 2018, 05:50 PM
Thank you. Its rewarding.
simonjb
Apr 28 2018, 09:00 PM
So I made some more progress, but two steps forward and one back. The paint shop had reattached the front suspension and all was done nicely - that’s when I went to reinstall the lower part of the steering shaft and hockey puck. Well, as most of you know, that can’t be done unless you drop the front suspension. Ugh. So I had to do all of that, and then placed the dust cover and new bearing and seal over the shaft before i raised up the suspension and guided the shaft through the body into the rear of the dash area. In any case, a few hours later and the steering was all reconnected.
porschetub
Apr 28 2018, 09:12 PM
Wow that car is sharp ,nice work really,way more flash than mine
bobboinski
Apr 28 2018, 10:27 PM
Your car is going to be beautiful. This is what I want to do when I really retire. Great work.
bbrock
Apr 29 2018, 09:04 AM
QUOTE(simonjb @ Apr 28 2018, 09:00 PM)
Maybe most know this, but not all, and you probably saved me from making that mistake when my car goes back together. I'm loving watching your showstopper go back together. Fantastic work!
