Not looking to measure amps, most multi - meters read milli- amps.
Even the free units from Harbor Freight will work.
Remove the battery negative, put the meter between the ground + (red) lead and the black lead to the battery neg post, check the draw 250 ma and above is pushing it.
Pull one fuse at a time, watch for a big drop, that's the problem.
ps: do not run the engine or big draw items (headlights, fans) that will burn out the meter configured like that.
QUOTE(914Toy @ Dec 30 2017, 03:06 PM)
QUOTE(BeatNavy @ Dec 30 2017, 02:22 PM)
QUOTE(Dave_Darling @ Dec 30 2017, 05:06 PM)
Do you have an ammeter? If so, hook it up between the battery ground post and the ground wire. See what the draw is with everything off. Anything more than a half an amp is way too much, especially in our old cars.
Start removing fuses. Note what fuses change the draw and how much. Then check what connects to those fuses to give you an idea where to look for the draw.
Numbers are better than "well it's a small spark".
--DD
I had a similar issue, and I did what Dave is describing with a multimeter. Turns out I had a parasitic draw of around 125 milliamps. That was enough to pretty much discharge the battery in a couple of days. I think you definitely want something below 25 milliamps, IIRC. In my case it was definitely the radio. I'm not sure if the power was wired wrong or if there was something else going on, but I ended up just taking the fuse out of the radio. Someday I'll fix it, but for now my "music" is the T4 motor...
Thanks for your responses. My meters do not measure amps, so I will see what happens with the radio power fuse removed as a first step. If that isn't enough I will locate an amp meter to do the sequential fuse removal routine.
