able2222
Jan 2 2018, 09:02 AM
Just put in a new 914 Rubber easy install MC and I have a slow drip from the banjo washers. I've cinched the hollow bolt down pretty tight (manual says 18 ft lbs) and it still leaks.
I think I need to replace the washers...anyone know the right size (one is bigger that the other) and source for these?
Thanks for any suggestions.
howlndog
Jan 2 2018, 12:20 PM
QUOTE(able2222 @ Jan 2 2018, 09:02 AM)
Inner is 10x16x1.5, outer is 12x16x1.5. Belmetric.com sells both. The M12 washer comes in several outside diameters... You may want to buy a few 18mm OD, just in case my aging memory is off by a few mm.
https://www.belmetric.com/solid-copper-gaskets-c-11_91/
