dwillouby
Jan 3 2018, 05:40 PM
Hello,
I am looking at producing some additional Hyd clutch master cyl mounting brackets again.
I will have to farm out to a shop to make as I no longer have access to a mill.
Bracket will be around $50.00. Trans bracket may be made as well. need final quote from m/s.
David
Click to view attachment Click to view attachment
ablesnead
Jan 3 2018, 08:19 PM
I would be interested in the whole kit....bracket (s)...master and slave..
bdstone914
Jan 4 2018, 08:09 AM
[quote name='dwillouby' date='Jan 3 2018, 05:40 PM' post='2564027']
Hello,
If you laser cut that bracket it about be about $10. Offering a whole kit made sense. What clutch master does that fit ? What pedal set is used ? Many missing pieces to the puzzle.
dwillouby
Jan 4 2018, 08:56 AM
[quote name='bdstone914' date='Jan 4 2018, 07:09 AM' post='2564185']
Hello,
[/quote]
If laser cut is acceptable (finish not as nice as machined) cost will come down.
I used a pedal set from a 76 for the prototype.
This uses the standard Wilwood master cyl. I can supply a list of part numbers / vendors. I cant get a better price on the parts than anyone else.
Made and sold several of these in the past with no complaints.
David
ablesnead
Jan 4 2018, 10:29 AM
part numbers will work for me..I find laser cutting to be excellent
913B
Jan 4 2018, 10:47 AM
Subscribing to thread. I am interested.
Mueller
Jan 4 2018, 11:55 AM
David,
Do you have a source for the laser cut parts? If not do you want me to get a quote for you for those being laser cut?
I have some parts I drew for someone else that I am sending off for quotes for a local shop to make.
No extra charge on my side, just pay for shipping and the parts with no additional mark up.
euro911
Jan 4 2018, 12:44 PM
I purchased one of David's kits a couple years ago and couldn't be more happy with it
Click to view attachmentClick to view attachment
dwillouby
Jan 8 2018, 03:45 PM
Thanks Mueller for the kind offer but I have a local shop quoting me for laser cutting now.
Also thanks Mark for the endorsement.
Should have final quote soon and work out a price for the M/C and slave brackets, slave mounting spacer and hardware ( longer brake m/c bolts and slave mount bolt).
Wont get rich from this just fun to do.
Thanks
David
shoguneagle
Jan 12 2018, 08:31 PM
I have used the Wilwood master and slave cylinders in making my conversion. Master 3/4 inch diameter; slave 7/8; believe the master cylinder model was the short version to clear the steering and bracing. The kit and mounting looks like my installation which is performing very well. Glad I made the conversion and not looking back
Very good looking kit and brackets.
dwillouby
Jan 22 2018, 10:25 AM
Hello,
I finally have some parts available.
Set includes;
M/C bracket
Slave bracket
Slave mounting hardware and spacer
longer bolts for brake M/C
Mounting hardware for clutch M/C
Additional parts list.
$56.00 shipped USA
Thanks
David
913B
Jan 22 2018, 12:16 PM
To clarify will the additional parts list include :
- Which master and slave to buy ?
- Any other items needed (i.e. a hydraulic line from the master to slave) ?
What about the how to modification for the clutch pedal to master cylinder ?
Thanks
Ted
dwillouby
Jan 22 2018, 12:58 PM
Yes the list details what parts are required.
I will provide a basic install guide.
Thanks
David
913B
Jan 22 2018, 05:21 PM
Sorry, last question, how much cutting/modification is required ?
Would it be possible to reverse the procedure someday ?
Paypal ?
Thanks !!
dwillouby
Jan 22 2018, 07:28 PM
You will need to use a 1.5 inch hole saw for m/c access. and drill a small hole to allow a -3 line to pass through.
Paypal works
David
dwillouby
Jan 24 2018, 08:57 AM
