All great suggestions above. The majority of fasteners on these cars are 13mm and 10mm, with a few 17mm, 19mm and 14mm. You can go a long way with just wrenches and sockets for those. But here's my list...
Early phases of the 914 addiction:
– Amazon prime membership and bookmarks for 914rubber, pelican parts, belmetric, Auto Atlanta. Also a large recycle bin for all the cardboard boxes
– Good 3/8 & 1/4 ratchet kit with medium and long extensions. Also deep sockets.
– Regular length metric spanner set
– Short (stubby) metric spanner set
– 3/8 M8 triple-square
– Rotating jaw-type 3/8 oil filter wrench
– T handle hex assortment
– 3/8 hex sockets in 4, 5 and 6 sizes
– Assorted length and size screwdrivers
– Assorted metric nuts and bolts
– 3/8 torque wrench accurate between 8 ft-lbs and 35 ft-lbs.
– Crimping tool and box of assorted spade, bullet and eye terminals
– A quality hydraulic jack and pin-type jack stands (stay away from the ratcheting style)
– Dremel with grinding and cutting discs
– Power drill with assorted bits and wire wheels
– Vice-grips
– Pry bar
Advanced disease:
–3HP Compressor and 1/2" impact wrench
–1/2 Impact socket set
–1/2" breaker bar
–1/2" torque wrench and sockets
–Quickjack or mid-rise lift
–Seal puller
–Bearing separator
–Multimeter for testing electrical circuits
–Tangerine Racing engine jack plate
–Mig welder
–Micrometer
–Shop press
–Shop crane with lifting straps
–Engine stand with type IV yoke
I'm sure there's more, but this should get you well on the road to addiction!
