QUOTE(76-914 @ Jan 7 2018, 11:28 PM)
QUOTE(simonjb @ Jan 7 2018, 06:32 PM)
QUOTE(76-914 @ Jan 7 2018, 07:45 PM)
Are you talking the radio block off plate? If it's the dash plate that goes from the Head light switch to the radio I have one out getting ready to cover. I can trace you a pattern and mail it to you. PM me because I may forget to come back to this post.
I am doing the same. How are you going to cut the vinyl? I was thinking of gluing the vinyl on, let dry, and then trim off the edges and make the cut-outs.
I laid the metal piece on the back of the vinyl and traced it out. Then I cut it out with scissors. Razor knifes tend to pull and stretch the material you are cutting. I will trim the holes with an exact-o knife after the glue has set. Be sure to use a glue that will withstand 160F. You want to leave about 1/8" extra (beyond the metal) where it goes over the steering wheel clamshell or you'll see the gap after it's installed. The cutout is a little large on the metal piece so you can slip it in and over that clamshell. Does that make sense? I'll post some pic's later this week (after the adhesive arrives) in my build thread detailing it
I think I get it. I'll try the same, cut, glue, dry, cut.
