QUOTE(pcar916 @ Jan 8 2018, 12:44 PM)
Hi Folks,
I have what I think is a 1.7L D-Jet engine but with no serial number, so I figure it's a replacement case. If it has the D-Jet intake but four intake manifold studs am I correct in thinking it's a 1.7L engine? Don't know as much about the fours!
I thought the early D-jets had a circular plastic air box and I've made no measurements of the intake runners to see if this engine has been converted into a 2L using 1.7L heads. Is that possible?
Ron
4 bolt intakes just means it doesn't have 2.0 914 heads. Based on that it could be 1.7, 1.8 or bus 2.0. If it is indeed an unnumbered case its going to be pretty hard to tell from the outside. 1.7 1.8 and bus 2.0 all had different intake setups so that might give an indication as to what it is but its no guarantee. pictures might help here but with no numbers without pulling a head and measuring it would be impossible to tell.
A couple more external things that may help improve your guess though are 1. Rocker arms (1.7 had different rocker arms than the 1.8s and 2.0s) 2. Distributor part number (provided it has one and it is assume to be original)
