Hi Folks,
This is a mostly complete Oklahoma City 1.7L car with full-length replacement longitudinal pieces included. $1000 and come pick it up. There is a slideshow at…
http://s346.photobucket.com/user/inv4me/slideshow/?sort=2
Sold as-is
PM with questions. Phone number on demand.
Thanks,
Ron
Notes:
1. Missing parts might still be discovered, we're still combing the warehouse for them.
2. This engine has a replacement case and no serial number on either of the normal places. It has a 2.0L induction system, but the stroke has not been established. So… not sure which displacement it is.
Description:
A. Front of car
Gas and vent tanks
Hood with
Wipers
Side marker lights
Parking light buckets and lenses
Wiper assembly
Eyelids
Headlight assemblies
Headlight sheet metal covers
Headlight valences
Heat / defrost / fan ventilation stuff (front trunk)
Front trunk board (carpeted… above spare tire/AC condenser) plywood is warped
Missing
Windshield (original was cracked)
Fuel tank fitting
Steering column bracket
Front sway bar
B. Middle of car
Full-length longitudinal-stiffeners for rusted out longitudinals
Likely a 1.7L or 2.0L Engine (See note above)
Tail-shifter transaxle
Doors (early)
Shifter w/ linkages
Idle lever
Heater flapper boxes
Smoothed top w/ both front clamps and 1 rear clamp
Seats (upholstery is rough)
Center console w/padded top
Interior sail panel pad
Sunshades
Top dash pad (cracked)
Lower dash pad with vents
Ign. switch
Turn signal / wiper switch assembly (on column)
Speedo cable
Peddle cluster
Door sill covers / hardware (less screws)
Trunk hinges and release mechanisms
Exhaust hanger
Engine compartment relay panel cover
Rocker panel covers (both)
C: Known missing items
Glove box & glove-box door
Seat belts
Taillight lenses
