QUOTE(simonjb @ Jan 10 2018, 09:48 PM)
QUOTE(Mark Henry @ Jan 10 2018, 07:24 PM)
Yes you can with the longblock, I do it all the time to put it on my engine stand and made a custom hook to do it. I can take a pic if you want.
But I wouldn't try it with a fully dressed engine.
For a fully dressed engine I lift with a chain bolted each end across the mount bar, in an upside down Y.
BTW a little FYI...never hammer that bit when trying to split the case, it will snap off.
Thanks. A pic would be great. I am lifting the engine to put on the heat exchangers and finish everything up and put on a lift table so I can then have it mobile.
Like I said
longblock only, below is a pic of what is known as a longblock.
Lifting the longblock is a fairly light load but add the weight of the shroud, mout bar etc and the load is much heavier across the nose. Plus if you add one heat exchanger the weight will shift off center and put a side load on the boss which is not very strong to start with.
What you are thinking of doing is very dangerous, working under any unsecured load is very dangerous. No different from working on a car with no jack stands, just a jack.
Besides the load is very unstable, it will move around all over the place, making it very difficult to manipulate and fasten the part and did I mention downright dangerous. This is pretty basic stuff taught in HS auto shop class and in any commercial shop you'd be reprimanded or likely fired on the spot.
I'd highly recommend googling work place safety and watching workplace safety videos or better yet take a couple of college continuous learning introductory auto shop courses.
You'd be better to install the engine and trans secure in the car, then install the exhaust.
