OK - time for an update here.
I've decided to run 3.2 so that changes some things.
One open item is where to source the bellhousing mounted throttle cable assembly.
Stock clutch cable is OK, right?
I’m using the stock clutch cable. Contact Rich - A914guy@aol.com He is the guy who makes the throttle bellcrank with an adaptor to bolt onto your stock 914 trans. He includes the 914-6 cable and correct shaft to connect the bellcrank to the throttle plate. You either need to modify the small ball connector on the throttle plate arm to the other side of the arm (my guy did it in 5 minutes) or buy a kit to do it from Sierra Madre. It’s a very easy mod but easier when the engine is out of the car.
Thank you, I just emailed Rich.
Ben, let's get the oil tank sorted out first before you spend anymore of my money!
When ever your ready. Let me know when you want to place the order.
