Top left looks like the piece that goes behind the right rear cylinder. The angular piece with curved channel goes under the left side (shift rod sits in the channel). The other angular piece goes under the right side. The other two pieces don’t look like the top tins. What kind of engine do you have?
LowBridge
Jan 14 2018, 03:43 PM
both red circles cover the pushrod tubes from under the motor around the heat exchangers. the other ones are what suround the motor and help seal the upper engine area.
